Hot water recirc line w/ instant water heater?
Discussion in 'Tankless Water Heater Forum' started by ffmedic7, Sep 4, 2006.
  1. ffmedic7
    ffmedic7 New Member
    Aug 26, 2006
    I have an instant water heater (as backup for solar heated water) and was wondering if anyone has any experience using a hot water recirculation pump with a demand heater.
    I understand that I will be circulating hot water back through the demand heater. Mine is designed to be used with preheated water, and has a modulating gas valve to turn off the flame when not needed.
    I just want to hear about any other issues folks might have run into with this setup.
    I do not have a return line, and have been looking into the valves that return back hot water into the cold line. Any thoughts?
    Thanks and Happy Labor Day!
    Matt
  2. jadnashua
    If you read the instructions, those that I've looked at specifically say do NOT use with a recirculator. Yours may be different.
  4. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    I believe this would overwork the on-demand heater causing early failure. There are recirculating systems that do not require a return line, but I would suggest that if at all possible you install a return line and use a recirculating pump designed to be use with a return. I have such a system in my home, and it works very well.
Similar Threads: water recirc
Tankless Water Heater Forum Tankless water heater, recirculation pump? Mar 25, 2012
Tankless Water Heater Forum Potable hot water recirculation pump. Mar 2, 2011
Tankless Water Heater Forum Price "guess" Tankless Water Heater/10 Gallon storage and existing recirc pump Jun 10, 2010
Tankless Water Heater Forum Tankless water heater with a small tank? Feb 3, 2017
Tankless Water Heater Forum Rheem water heater need trouble shooting. Jan 14, 2017
