Hot Water Issue
Discussion in 'Shower & Bathtub Forum & Blog' started by Scott-unlv, Mar 9, 2009.
  1. Scott-unlv
    Scott-unlv New Member
    Mar 9, 2009
    I have a hot water issue with my tub. I cannot get hot water to come out of the tub faucet. I am, however, able to get hot water to flow from the shower head. This has become a nuisance because whenever we give our 2 year old a bath we have to use the showerhead to fill the tub.
    The tub has a single handle tub/shower control. I replaced the cartridge thinking that maybe something was preventing a full flow of hot water from reaching the faucet, but this didn't work.
    Does anyone have an idea on how fix this?
    Thanks,
    Scott
  2. jadnashua
    The only thing I can think of is the high temperature limit adjustment in the valve, but that would affect both the shower and tub. All new shower valves are required to have a mechanical limit adjustment to limit the maximum temperature from the valve. You may just need to adjust that. Depends on the valve how that is done.
  4. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    How do you heat your hot water?
    Sounds like a flow related issue.
  5. Scott-unlv
    Mar 9, 2009
    Thanks for replies guys.
    The water is heated by an oil heater, which is on the opposite side of the house.
  6. Redwood
    Dec 15, 2007
    Service Plumber
    Is it a coil in a boiler, Indirect tank, or an oil fired tank type?
  7. Scott-unlv
    Mar 9, 2009
    It has a coil in it.
Similar Threads: Water Issue
Shower & Bathtub Forum & Blog Moen shower valve issue when water heater drained. Jan 13, 2017
Shower & Bathtub Forum & Blog New water heater issue?? Apr 15, 2016
Shower & Bathtub Forum & Blog hot water tap issue Nov 18, 2010
Shower & Bathtub Forum & Blog Water pressure issue in tub faucet May 8, 2010
Shower & Bathtub Forum & Blog Hot water issue in master Jan 9, 2010
