Hot water insufficient
Discussion in 'Water Heater Forum, Tanks' started by 123peanut, Jan 4, 2010.
  1. 123peanut
    123peanut New Member
    Jan 4, 2010
    California
    My son is having a problem getting enough hot water. He has an older gas water heater that had been working fine until a couple of weeks ago, could not get enough hot water without turning the temperature control all the way up. I'm thinking it may be the thermocouple ? I had a similar problem a few years ago but it turned out to be a leak in the hot water line under the slab. I have also had the thermocouple problem as well.
  2. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    It's not a thermocouple...
    It could be another slab leak is the water heater running almost constantly even when hot water is not being used?
    it could be a bad t-stat as well
  4. jadnashua
    What is the temperature of the water when first used? Is this electric or gas? If it starts out okay and quickly cools off, it could be cross-over - the dip tube could be broken up and essentially no-existent. How old is the unit?
  5. Redwood
    Dec 15, 2007
    Service Plumber
    Could be a bunch of stuff...
    But not the thermocouple...
  6. 123peanut
    Jan 4, 2010
    California
    Thanks for all the suggestions. Whatever the problem was, it has stabilized and he does not want to pay someone at this point to inspect it.
Similar Threads: water insufficient
Water Heater Forum, Tanks Water Heater TP Valve Discharge Location - basement w/ no drain Tuesday at 3:50 PM
Water Heater Forum, Tanks Water heating Monday at 7:57 PM
Water Heater Forum, Tanks My T&P valve is expelling 1 cup of water per day Monday at 11:17 AM
Water Heater Forum, Tanks Adding heat pump water heater alongside ancient boiler coil Feb 15, 2017
Water Heater Forum, Tanks Help picking electric water heater Feb 11, 2017
