sspin
Hi,
I just had some remodeling done, moving a bathroom and leaving an existing bathroom as it was. I also just moved into this house, so don't have a lot of history.
I have a Amtrol indirect fired hot water tank with Gas fired boiler/furnace. The Hot water tank is working as it should. The water is hot.
All hot water in the house is on a single line from the hot water tank. It runs from the tank, to the kitchen faucet, dishwasher, to bathroom #1 to bathroom #2. Bathroom number #1 is still the original plumbing. Bathroom #2's plumbing was moved from 1 side of the house, to the other.
Also, I just replaced the kitchen faucet from a standard single spout moen to a single spout Delta (touch), but plumbing was not changed there.
Now, in the morning, the hot water in bathroom #1 (both shower and sink faucet) is only luke warm.
If I go the kitchen sink, the water is Hot as it should be.
If I turn the Hot water on at the kitchen briefly, the water in bathroom #1 immediately gets HOT too.
Note, the kitchen faucet does not need to stay running Hot for bathroom #1 to get hot. Only turning it on briefly does it.
This scenario is somewhat random, so it is hard to diagnose.
Although I can not confirm, I expect that bathroom #2 will exhibit the same symptoms, but I have not been able to verify yet.
Water pressure is fine everywhere.
Is it possible that there is a vapor lock somewhere and briefly turning on the kitchen faucet clears it?
Thanks a lot
Thanks a lot
