Hot Water heater Connections
pilotboat
New hot water heater (GE) has female galvinised pipe fittings built flush to the surface of the tank. A galvinished pipe riser is installed so it can be piped onto a copper adapter. My question is "dosen't the two disimilar metals cause problems down the road?"' and "should pipe dope or teflon tape (or both) be used between the copper fitting and the gal pipe?"
GoTanklessToday
Renton, WA
pilotboat said:
New hot water heater (GE) has female galvanized pipe fittings built flush to the surface of the tank. A galvanized pipe riser is installed so it can be piped onto a copper adapter. My question is "doesn't the two dissimilar metals cause problems down the road?"' and "should pipe dope or Teflon tape (or both) be used between the copper fitting and the gal pipe?"
Where I'm from, we use flexible copper connectors that are designed to attach to galv fittings. You must use dielectric union if you are going to run your copper water lines straight to the heater.
And by the way, its a cold water heater, not a hot water heater. haha
Gary Swart
Yakima, WA
The tank should have had the nipples included. They are not galvanized, but a material that will safely make the transition to the copper flex lines. I use the old fashioned pipe compound rather than tape, but tape will work.
Markts30
Commercial Plumber
Phoenix, AZ
If you have a re-circ system, it could be considered both...LOL
Randyj
Alabama
Boy am I confused... I thought it was a heater that made the cold water hot???? Or does the heater make it cold???? HELP>>> I'm going to weird out.
heater
if you are going to pedantic over semantics, then it is a "cold water heater" for a couple of minutes until the water is raised one degree. Then it becomes a "warm water" heater until the water temperature increases even more. At that point it becomes a "hot water" heater until the thermostat is satisfied.
