Hot Water Flow to Shower Issue
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by TheSisko, Dec 7, 2012.
  1. TheSisko
    TheSisko New Member
    Jul 8, 2006
    When the shower is going, suddently there will be a very noticeable and cold reduction in water pressure and hot water. Obviously, the loss is from the hot side. No other showers/baths/or water used at the same time. In fact, it happens when the shower is used before anyone else.
    The flow will cut back on after about 30 sec, but it won't be near as hot as when the shower started. Crazy. Need help
  2. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    You have a tankless water heater?
  4. TheSisko
    TheSisko New Member
    Jul 8, 2006
    No
    Reg. gas-fired HWH. About 4 Y/O
  5. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    Then the problem is likely to be the pressure/balancing/anti-scald valve inside the shower valve.
  6. hj
    You have a problem that needs someone there to check it while it is happening. You do not have enough information for us to make a diagnosis. If you have a circulation system, then a bad check valve would cause those symptoms, but turning on the hot water in a sink would change the water back to hot again. But this is only one possibility among many.
  7. TheSisko
    TheSisko New Member
    Jul 8, 2006
    This is what I'm thinking, too
    If this IS the prob, will it get worse? I can live w/this but if its gonna get worse, I pretty sure I'm gonna get it fixed over the holidays
Similar Threads: Water Flow
Plumbing Forum, Professional & DIY Advice Where can backwater/backflow valves be used in a building? Nov 29, 2016
Plumbing Forum, Professional & DIY Advice Increase flow from water line to fridge Nov 8, 2016
Plumbing Forum, Professional & DIY Advice Concerning backflow [water contamination] issue, advice needed Oct 16, 2016
Plumbing Forum, Professional & DIY Advice Reduced Water Flow in Single Bathtub Faucet Aug 28, 2016
Plumbing Forum, Professional & DIY Advice Drained water heater, flow worse Jul 26, 2016
