Hot water dispenser leak
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Joerg, Dec 2, 2006.
  1. Joerg
    Joerg New Member
    Oct 6, 2004
    Califonia
    Hello Folks,
    While fixing another leak I noticed that the Insinkerator hot water dispenser is a bit wet underneath. Searched the web, found there was a recall, unplugged it and now waiting for the kit. The recall said there is a fire risk if the tank leaks but all they send out seems to be a piece of plastic insulation. Question: How can the tank leak? Is there a "neuralgic point" on those things that tends to leak or is the thing pretty much shot?
    I could take it all out but it's really tight in there and without losing 30-40 pounds I have a very hard time squeezing in there. Checked the three top connections and the drain plug, all dry.
    Regards, Joerg.
  2. Cass
    Cass Plumber
    Nov 12, 2005
    Do you know how old the unit is and if it is under warranty?
  4. hj
    dispenser
    Probably time to scrap it, or at least get a new tank.
  5. hj
    dispenser
    Probably time to scrap it, or at least get a new tank. If you
  6. hj
    dispenser
    Probably time to scrap it, or at least get a new tank. If you get just the tank,
  7. hj
    dispenser
    Probably time to scrap it, or at least get a new tank. If you get just the tank, be sure to
  8. hj
    dispenser
    Probably time to scrap it, or at least get a new tank. If you get just the tank, be sure to ask how to
  9. hj
    dispenser
    Probably time to scrap it, or at least get a new tank. If you get just the tank, be sure to ask how to convert from the old lines to the new tank because there are differences.
  10. Joerg
    Joerg New Member
    Oct 6, 2004
    Califonia
    Hello HJ, Cass,
    It's at least 10 years old. So maybe it is indeed time for a new one. I don't mind the expense but I do mind squeezing down in there. That typically results in back pain :(
    I just thought there was some area where they "usually" leak. Like some TV sets in the olden days where you could almost fix them in your sleep because it was always the same capacitor that blew.
    Regards, Joerg.
  11. Dunbar Plumbing
    Dunbar Plumbing Master Plumber
    Apr 18, 2005
    Service Plumber, Outdoor Temperature Relief Owner
    Me thinks old age has hit hj
    It's all downhill from here buddy :eek:
Similar Threads: water dispenser
Plumbing Forum, Professional & DIY Advice Air Gap pumping water outside, Dishwasher, Air Gap and Garbage Dispenser all are new Oct 4, 2015
Plumbing Forum, Professional & DIY Advice Insinkerator hot water dispenser tank with non insinkerator faucet? May 30, 2015
Plumbing Forum, Professional & DIY Advice Hot water dispenser help Jan 20, 2013
Plumbing Forum, Professional & DIY Advice Instant hot water dispenser Oct 10, 2011
Plumbing Forum, Professional & DIY Advice Instant Hot Water Dispenser Problem Feb 6, 2011
