bruno
I'm hoping I can find some insight on this forum. Thank you in advance!
I am in a 6 unit condo, we have a hot water recirculation loop with pump on a timer. The system has no balancing valves. My kitchen faucet takes a long time to receive hot water. Below are the times and temps I recorded to receive hot water. For reference I've attached a layout diagram and images. My unit is #5.
Times in min:second
With pump on
30 seconds = 71*F
1 min = 103*F
1:30 = 115*F
With pump off
1:00 = 86*F
2:00 = 89*F
3:00 = 88*
4:00 = 88*F
5:00 = 89*F
7:00 = 95*F
13:00 = 111*F
When the pump is running the faucet will eventually receive 125*F, which is the set point at the water heater.
The worst case, when the pump is off, occurs when no one else in the building creating no demand at the end of the line to pull hot water. My bathroom fixtures do not have the same issue as the kitchen, presumably because it's closer to the water heater.
After reading some articles on here I thought the remedy could be a check valve after the last fixture; in the crawl space under unit 2. But then I noticed what looks like a check valve after the pump; see attached image. With a check valve after the pump it would stop a fixture from pulling water from the return line, right? Even if the check valve and the fixture are that far away from each other?
Thanks again,
Bruno
*edited for clarity
Times in min:second
With pump on
30 seconds = 71*F
1 min = 103*F
1:30 = 115*F
With pump off
1:00 = 86*F
2:00 = 89*F
3:00 = 88*
4:00 = 88*F
5:00 = 89*F
7:00 = 95*F
13:00 = 111*F
Thanks again,
Bruno
*edited for clarity
