Hot water boiler installation
Discussion in 'Boiler Forum' started by bobscott, Feb 28, 2011.
  1. bobscott
    bobscott New Member
    Feb 28, 2011
    New York
    We are looking to install two 250,000 btu boilers and two 110 gallon holding tanks to provide hot water to a 40 unit apartment building. What would be the best way to install them to get the most redundancy and efficiency? (each feed tank individually, then join them after the tanks, in sequence, etc?)
    Thanks.
  2. tk03
    tk03 New Member
    Jan 31, 2011
    Harrisburg, pa
    Are these mod/cons or cast iron boilers. Use indirect water heaters for the hot water. Whose tanks are you using?
    Piping will depend on boilers
  4. bobscott
    bobscott New Member
    Feb 28, 2011
    New York
    These are Lars copper core boilers. We were not planning on using tanks with a coil.
  5. Tom Sawyer
    Tom Sawyer In the Trades
    Nov 29, 2010
    Maine
    bob, I would probably stage fire the boilers and run the water tanks in paralell
  6. bobscott
    bobscott New Member
    Feb 28, 2011
    New York
    What does it mean to stage fire the boilers?
    Thank you.
  7. Tom Sawyer
    Nov 29, 2010
    Maine
    They fire to demand. On low demand a single boiler fires, as demand increases the 2nd boiler cuts in. Re-set modulating controls would be a very good addition also.
  8. tk03
    tk03 New Member
    Jan 31, 2011
    Harrisburg, pa
    I would agree with Tom about stage firing. I would probably pipe them as reverse return to balance the flow between the tanks.
  9. Tom Sawyer
    Nov 29, 2010
    Maine
    Post a diagram of that reverse return for the tanks. I wann see that one LOL
Similar Threads: water boiler
Boiler Forum Draining and refilling a Burnham Boiler and Indirect Water Heater Combination Nov 29, 2016
Boiler Forum Winterizing hot water boiler vs. condensing boiler Nov 21, 2016
Boiler Forum Water radiator with condensing boiler? Oct 19, 2016
Boiler Forum water supply valve for gas boiler not fully closing Oct 12, 2016
Boiler Forum Weil McLain hydronic boiler water feed question Sep 29, 2016
