Hot water at cold side all faucets
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by ben1111, Jun 21, 2010.
  1. ben1111
    ben1111 New Member
    Jun 21, 2010
    illinois
    Hello,
    I have a home in Chicago that has hot water to all faucets on cold side. There are Grohe thermostatic valves at all showers (4). Only recent work was a new water heater 3 months ago. I am at a loss any help would be appriciated! Thanks in advance!
    Ben
  2. Esquire
    Esquire Plumber
    Nov 26, 2009
    Newfoundland
    Were they normal at some point? If just one of those faucets was failing there could be a potential cross connection. I have seen a couple of occassions where this has happened, but it has usually been with a cheap brand faucet.
  4. MASTERPLUMB777
    MASTERPLUMB777 Member
    Aug 6, 2007
    Retired Master Plumber
    Texas
    Or more likely eather the water heater was hook up wrong i have seen even professional
    plumbers do this !
    Or you could be missing the dip tube ?
    If this problem started about same time as wtr/htr was changed out that is where you
    need to start looking !
  5. MASTERPLUMB777
    Aug 6, 2007
    Texas
    Check your messages on your profile page ! ! !
  6. hj
    Reversing the connections to a water heater does NOT change the hot/cold orientation of the faucets. ALL it does is reduce the amount of hot water available. Changing hot to cold, and vice versa, requires a piping change somewhere.
  7. jimbo
    jimbo Plumber
    Do you have any kind of recirulating system? A failed check valve or improperly installed system could be a problem. If you have a retrofit recir, then warm to hot at the cold tap is a normal side effect. If you run a cold tap for a few minutes, does it turn cold, or stay hot?
  8. ben1111
    ben1111 New Member
    Jun 21, 2010
    illinois
    Thanks for the replies. There is not a recirc line, and the water heater was replaced 3 months ago and worked fine untill three days ago. I think that the check valves in one of the Grohe thermostatic mixing valve hav gone bad allowing the water to pass? They are all about 4 years old. I have read that the washing machine selonoid gould also be bad. I will look further into this, and hape to find a resolution to it.
    The water will eventually get "cold", but stays warm for a while!
  9. hj
    Washing machine solenoid valves CANNOT cause the problem, regardless of what you have heard.
Similar Threads: water cold
Plumbing Forum, Professional & DIY Advice Broke my cold water stem for my shower. Options? Tuesday at 10:06 PM
Plumbing Forum, Professional & DIY Advice Moen shower head cold water only after shower remodel Jan 18, 2017
Plumbing Forum, Professional & DIY Advice Cold Water Line to Kitchen not Working Jan 9, 2017
Plumbing Forum, Professional & DIY Advice Cold water relief valve question Nov 11, 2016
Plumbing Forum, Professional & DIY Advice Cold water supply line connected to cast iron main stack? Oct 27, 2016
