hot switch plate
Discussion in 'Electrical Forum discussion & Blog' started by Catherine, Jul 8, 2008.
  1. Catherine
    Catherine New Member
    May 30, 2008
    Hi
    I just turned off my kitchen light switch (recessed lights, dimmer) and it feel hot to the touch. I have never noticed this before. I have had that switch and lights for about 2 1/2 years. Is this dangerous? It is not as hot, but still warm, now that I have turned it off.
    Thanks for any help, I am quite nervous about this
    Catherine
  2. jimbo
    jimbo Plumber
    San Diego, CA
    Dimmers can be warm.. You could check and make sure that all the connections are tight, and that the dimmer is rated for at least the amount of watts load you have on it.
  4. Chris75
    Chris75 Electrician
    Aug 12, 2007
    Electrician
    Litchfield, CT
    all dimmers will feel warm to the touch, especially the plate screws if using plastic plates, Pretty normal and will not burn your house down... :D
  5. hj
    dimmer
    Resistor dimmers have convert electricity into heat and the heat has to go somewhere.
  6. Catherine
    May 30, 2008
    Thanks
    Thank you so much for your answers! I am relieved that my wall is not about to burn down!
    Catherine
  7. hj
    hot
    We did not say that, because you could actually have a problem. We just told you why you might not have one. For example, someone with aluminum wiring AND a dimmer could have a loose connection which would also heat up the box while the light was on. In that case our statements would still apply, but they would not apply to, or correct, the real problem.
Similar Threads: switch plate
Electrical Forum discussion & Blog Adjusting wall plates - Moving switches & receptacle outward so wall plate looks good Dec 29, 2009
Electrical Forum discussion & Blog Transfer switch connections Today at 10:44 AM
Electrical Forum discussion & Blog Light Switch wired to receptacle. Can I use to add recessed lights? Sunday at 6:17 AM
Electrical Forum discussion & Blog Lights will not turn on using 3 way switch Mar 5, 2017
Electrical Forum discussion & Blog Activating Pump via low voltage switch input Feb 11, 2017
