hot cold reversed? single back and forth handle in kitchen
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by 68malibu383, Nov 12, 2010.
  1. 68malibu383
    68malibu383 New Member
    Dec 15, 2009
    Colorado
    Hi,
    This is a faucet with a single arm on the side of the fixture that you tilt downward at about a 45 degree angle to get water to flow. Then push it back (counterclockwise) and forward for hot and cold. I think hot should be on when pushing handle back (counterclockwise). Is this correct, or should hot be forward? Thank you!
  2. shacko
    shacko Master Plumber-Gas Fitter
    Jan 22, 2006
    Rosedale, Md
    If we knew the brand and model we could answer the question easier
  4. Cookie
    Cookie .
    Oct 7, 2005
    Hot is back or to the left.
    If you would like to fix the problem go underneath your sink, turn the 2 valves to the off position, turn on the faucet and make sure the water is off, take the 2 supply lines and switch them from whatever they are connected to to the opposite one as long as they will reach. If the supply lines are not flexible, I would suggest that you go to a big box store and buy 2 flexible supply lines and replace what is there with the new lines. This is something that is taught in first year plumbing school. Have a nice day. :)
  5. 68malibu383
    Dec 15, 2009
    Colorado
    Thanks. I'll get it right.
  6. Cookie
    Cookie .
    Oct 7, 2005
    Please drop 150.00 in the mail for me. lol Thank you. ;)
    Once you become a regular customer you will get a 25% discount off of my regular prices.
  7. hj
    45 degrees downward, back, counterclockwise, and forward may mean something to you, but I cannot figure out where the handle is located on the faucet, or which way the handle is moving. Often with single handle faucets it is just a matter of rotating something 180 degrees to change the orientation of hot or cold.
  8. Cookie
    Cookie .
    Oct 7, 2005
    I understand that about Moens but what other ones can that be done with?
  9. Basement_Lurker
    Basement_Lurker One who lurks
    Jun 21, 2007
    I smash things and demand money.
    Victoria, BC
    Moen and Delta single cartridge units can reverse their intakes. I only install the occasional american standard faucet or p.i.a. grohe, but I think they can as well.
  10. hj
    Delta kitchen faucets do not reverse, but some versions of Grohe, and those that use a "tubular core" do.
Similar Threads: cold reversed
Plumbing Forum, Professional & DIY Advice Hot and cold reversed in whole house + single lever faucet backwards Jun 1, 2014
Plumbing Forum, Professional & DIY Advice Plumber reversed the hot and cold faucet placement, can it be fixed? Aug 25, 2012
Plumbing Forum, Professional & DIY Advice Hot and cold reversed on Moen single handle faucet Nov 10, 2011
Plumbing Forum, Professional & DIY Advice Bathroom shower hot/cold reversed? Jun 12, 2009
Plumbing Forum, Professional & DIY Advice Thermostatic shower valve - reversed hot/cold Mar 2, 2009
