Hot/Cold Reversed on Moen Single Handle Shower Knob
Discussion in 'Shower & Bathtub Forum & Blog' started by sixgun95, Apr 15, 2012.
  1. sixgun95
    sixgun95 New Member
    Mar 19, 2012
    Scottsdale, AZ
    Had a plumber come by yesterday and he installed a new stem. Now the hot/cold is reversed. Really want the hot back on the left side. I read here that all you do is remove the handle and turn the stem 180 degrees? How do you turn the stem? Does it matter if I turn it clockwise or counterclockwise?
  2. Hackney plumbing
    Hackney plumbing Homeowner
    Jan 6, 2010
    Alabama
    yes remove the handle and turn 180 degrees with some pliers. Turn it either direction. You do not have to turn the water off. It is simple...dont try to make it hard.
  4. sixgun95
    sixgun95 New Member
    Mar 19, 2012
    Scottsdale, AZ
    Got it, thks.
  5. hj
    Depending on the valve, you either turn the stem or the entire cartridge. If you pull the handle to turn it on, then you rotate the stem. If you turn the handle to start the flow, then you have to extract the cartridge and turn the entire thing 180 degrees.
  6. sixgun95
    sixgun95 New Member
    Mar 19, 2012
    Scottsdale, AZ
    Just turning the stem did it, thanks.
  7. gere
    gere New Member
    Jan 23, 2013
    Prince Edward Island
    Thank you so very much. Husband & I followed your advice and in a few seconds it was fixed. Didn't want to bother the plumber for such a small matter! This is my first time on this site and my compliments.
    gere
Similar Threads: Hot/Cold Reversed
Shower & Bathtub Forum & Blog Hot/Cold Reversed Oct 22, 2008
Shower & Bathtub Forum & Blog Hot/Cold Reversed; Kohler Shower Valve Mar 2, 2006
Shower & Bathtub Forum & Blog Hot/Cold Reversed in Shower - How Hard to Fix? Oct 19, 2005
Shower & Bathtub Forum & Blog Mixet Hot/cold Reversed? May 31, 2005
Shower & Bathtub Forum & Blog Hot/Cold Reversed & Metal Sliver in Delta faucet Oct 8, 2004
