Hot/Cold Reversed in Shower - How Hard to Fix?
Discussion in 'Shower & Bathtub Forum & Blog' started by Bustergordon, Oct 19, 2005.
  1. Bustergordon
    Bustergordon New Member
    Oct 19, 2005
    Hi! I am buying a condo where the hot and cold has been reversed on the shower. The shower fixture is a Kohler. The seller has said that they are not going to be responsible for fixing this, because it requires that they tear out the tile and the drywall to fix. Is this right? I did a bit of research and it seems that a lot of brands are easier to fix (just remove the fixture and reverse the cartridge).
    If it helps, this is a new Kohler fixture (it was installed in the last year).
  2. jimbo
    jimbo Plumber
    Many of the Kohler are also reversible. If you go to the Kohler website and find your model type, then download the installationsheet for that type of valve. I looked at the RiteTemp pressure balanced and it is reversible. They make a jillion trim kits, so you have to be sure what valve type you have.
Similar Threads: Hot/Cold Reversed
Shower & Bathtub Forum & Blog Hot/Cold Reversed on Moen Single Handle Shower Knob Apr 15, 2012
Shower & Bathtub Forum & Blog Hot/Cold Reversed Oct 22, 2008
Shower & Bathtub Forum & Blog Hot/Cold Reversed; Kohler Shower Valve Mar 2, 2006
Shower & Bathtub Forum & Blog Mixet Hot/cold Reversed? May 31, 2005
Shower & Bathtub Forum & Blog Hot/Cold Reversed & Metal Sliver in Delta faucet Oct 8, 2004
