Tintin
I have pex stubbed out of the wall down low and need to run the line up the behind the electric water heater to make the connections at the top--what's the best way to do this? Should I connect the pex to flexible copper pipe and secure those lines to the back wall as they go up? Can I stick with pex all the way up and make a connection at the water heater, or is it not code to use PEX for the connection? I usually see the flexible lines running down from above, so I'm not sure the best way to run the pipe up from below is? Thanks for the advice!
