Hose clamp will not seal!
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by jok, Jan 1, 2013.
  1. jok
    jok New Member
    Jan 29, 2012
    Oregon
    This shouldn't be so difficult. Dishwasher drain is connected to garbage disposal. Existing rubber connector that connects hose to disposal cracked and was leaking. No problem, just replace the rubber coupling.
    Went out and bought a new $2.99 Lasco coupling, slipped one end over the disposal connection and the other over the 1/2" copper pipe that was connected to the 5/8" ID dishwasher hose, and tightened the hose clamps.
    The small ID end of the new rubber connector leaks. Things I've tried: replaced 1/2" copper with 1/2" barbed poly; tried different hose clamps; loosened hose clamp; tightened hose clamp. See photo. You can see a drop of water about to drip.
    What am I missing? Obviously, the new connector is not sealing around the barbed fitting. Is the barbed fitting just too small? I'm using 1/2", but 3/4" seems too big. Are these connectors known to be oversized such that they're too loose?
  2. hj
    Cut off the end of the Lasco coupling at the "step" that fits your DW's hose and slide the hose, with the copper tubing inside it, into the coupling, then use a "screw type" hose clamp.
  4. jok
    jok New Member
    Jan 29, 2012
    Oregon
    Thanks very much, HJ! I waited a few days to reply, so I could run the dishwasher a few times. It definitely did the trick.
    So, is your description the "correct" way to do it, or is it just a solution to this symptom of a slightly oversized connector? Just curious for the next time. Thanks!
  5. hj
    quote; So, is your description the "correct" way to do it, or is it just a solution to this symptom of a slightly oversized connector?
    It could be either, but then I have never seen a "oversized" connector. It is the way I do it, when I have had to work with hoses which have had the end cut off to connect to an air gap since I was discontinuing it.
Similar Threads: Hose clamp
Plumbing Forum, Professional & DIY Advice Torquing hose clamps for poly connections Feb 18, 2012
Plumbing Forum, Professional & DIY Advice Quality hose clamps Dec 23, 2006
Plumbing Forum, Professional & DIY Advice Help - washing machine hose and standpipe issue Jan 20, 2017
Plumbing Forum, Professional & DIY Advice Hose Bib Bonnet Packing Jan 5, 2017
