Horizontal vent question
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by nculbertgm, Jan 20, 2008.
  1. nculbertgm
    nculbertgm New Member
    Jan 20, 2008
    I want to use a common drain for a tub and a shower. The most convenient point to tie the two drains together (each has its own trap) is in the center of the bathroom and I would install a single vent connection just before the two drains join. That would necessitate running the vent horizontally about 10 feet to reach a wall and then turning the vent vertical and taking it through the roof. The horizontal portion of the vent would maintain a 1/4" per foot slope. The IRC applies and the installation is in a one story house.
    A schematic of the proposed piping is available on
    http://s253.photobucket.com/albums/hh75/nculbertyh/
    The santee used for the vent connection would be installed with the vent branch in the vertical position.
    Is there a limit to how long the horizontal portion of the vent can be?
  2. jimbo
    jimbo Plumber
    A vent can NOT run horizontal at all until it is 42" above the floor, or 6" above the flood rim of all the fixtures. It must come off the drain via a wye rolled to 45º and continue not less than 45º upward, until the 42" height is reached.
  4. Terry
    Aug 17, 2004
    The tub should be vented too, and the two vents tied together above the 42" level.
    Or at the least, 6" above the top of the tub.
    Like Jimbo mentioned, the vents need to be rolled above the flow line of the pipes.
  5. nculbertgm
    Jan 20, 2008
  6. seaneys
    seaneys New Member
    May 8, 2007
    Chicago Suburbs
    I must be missing something. How would you vent any floor drains that are next to a wall (say a shower drain that is centered in a 40x48 shower)? Wouldn't you have to run horizontal for a few feet until you can shoot up into the wall?
  7. jimbo
    jimbo Plumber
    The trap arm runs horizontal, typically to a vertical tee, and the vent comes off vertical. If the vent must be taken off a horizonal pipe, it is done with a wye rolled to a 45º and the vent pipe must rise at least at 45º until it is above the flood rim of fixtures.
  8. seaneys
    seaneys New Member
    May 8, 2007
    Chicago Suburbs
    Argh....
    Illinois Plumbing Code:
    b) Vertical Rise. Where vent pipes connect to a horizontal soil or waste pipe, the vent shall be taken off above the center line of the soil or waste pipe, and the vent pipe shall rise vertically, or at an angle not more than 45 degrees from the vertical before offsetting horizontally or before connecting to the branch vent. (See Appendix K: Illustration G.)
  9. seaneys
    seaneys New Member
    May 8, 2007
    Chicago Suburbs
    If you are draining into a horizontal line, could the vent be taken off upstream of where the trap arm connects?
Similar Threads: Horizontal vent
Plumbing Forum, Professional & DIY Advice UPC horizontal wet vent (please help) Dec 15, 2016
Plumbing Forum, Professional & DIY Advice Vent running horizontally below flood level of rim of fixtures May 31, 2016
Plumbing Forum, Professional & DIY Advice Vent exit horizontally through gable? May 26, 2016
Plumbing Forum, Professional & DIY Advice Bathroom Horizontal Wet Vent W Direction Change? May 6, 2016
Plumbing Forum, Professional & DIY Advice Dry horizontal vent below the flood level of a fixture........ Jan 9, 2016
