horizontal toilet drain
Discussion in 'Toilet Forum discussions' started by beddows, Sep 13, 2007.
  1. beddows
    beddows New Member
    Sep 13, 2007
    I live in a 3 story townhome with both baths on the upper floor. My wife has hip problems & I would like to put a small bathroom on the main floor. I have a suitable area, but it is above a finished rec room. This rec room already has a boxed in area in the ceiling for heat ducts that i can expand to handle the toilet plumbing. The issue is that to get over to the main sewer in the garage,will entail about a 15 ft horizontal run with possible 2 90's in it before tying into the existing drain. Will this be an issue?
    See photos at http://www.vancouver.hm/bath.html
  2. jadnashua
    As long as you can get the slope you want, no. That may require a cleanout at one or both of the 90's, though. One of the plumbers will know for sure.
  4. markts30
    markts30 Commercial Plumber
    Sep 25, 2006
    Commercial Plumber
    Phoenix, AZ
    Seems like the waste would not be too much of an issue but the venting will require a bit of tearing up of the floor above to route pipes into the attic to tie into existing vents...
    We can run up to 135 degrees of horizontal bend before we need a cleanout in UPC-land...
    You don't say where you are so we are at a bit of a loss to help here....
  5. patrick88
    patrick88 Plumber
    Sep 3, 2007
    plumber
    Webster Ma.
    Should be a clean out at every change of direction. MA. State Code
Similar Threads: horizontal toilet
Toilet Forum discussions Toilet to Horizontal 3x3x2 Sani Tee Oct 25, 2016
Toilet Forum discussions Happy D toilet WALL (rear/horizontal) outlet model installation Oct 24, 2013
Toilet Forum discussions will a pressure assisted toilet help horizontal drain flow? Nov 16, 2011
Toilet Forum discussions What can I do with a long horizontal run and no pitch? Jun 3, 2015
Toilet Forum discussions Toilet Flange not Flat/Level Today at 2:21 PM
