Hopelessly clogged
Discussion in 'Toilet Forum discussions' started by arapahoepark, Apr 8, 2013.
  1. arapahoepark
    arapahoepark New Member
    Apr 8, 2013
    Colorado
    Hey, the past day or two the toilet was clogged after a large ... but, I digress. It's been able to go down since however, it is slower than it used to. We've tried plunging with different plungers, using vinegar and baking soda, and clorox a couple times each. Someone, does not want to use the snake which I think it might help but this person in the house (who shall remain anonymous) doesn't want to thinking it won't work and it takes too much.
    Any advice??
  2. johnjh2o1
    johnjh2o1 Plumbing Contractor for 49 years
    Aug 9, 2009
    Retired
    Florida
  4. Stephen411
    Stephen411 New Member
    Apr 8, 2013
    Kitchener, ON
    It's common to see toilet paper getting snagged on a sharp edge of the toilet flange. Somebody also could have flushed a toothbrush or a Q-tip and no amount of clorox will clear that. I would remove the toilet, inspect the flange and check for debris. If it passes this test, then it will be much easier to snake the drain with the toilet removed.
  5. johnjh2o1
    Aug 9, 2009
    Retired
    Florida
    If I pulled the toilet every time I was called out on a toilet stoppage, before trying to clear it with a plunger and auger I wouldn't have many repeat customers. Pulling the toilet is the last option.
    John
  6. suceress
    suceress Member
    Mar 12, 2008
    LA
    I have to agree with you here. Best to try the auger and if that fails, take the toilet off.
  7. Cameron Fields
    Cameron Fields Implementer/Inventor
    Mar 5, 2013
    2 year lawn , Theorist, Designer/inventor,Animator
    Florida
    you can try to flush a bio diaper or a small bio wash cloth other than that you are stuck with the auger.
  8. Terry
    Aug 17, 2004
    [​IMG]
    We use a closet auger with the large 1-3/8" end on it.
    Smaller cables can go right by the obstruction and not move it.
    [​IMG]
    I wouldn't try flushing more wash clothes down like Cameron suggests. I think he's just messing with you.
Similar Threads: Hopelessly clogged
Toilet Forum discussions When toilet's clogged, flapper won't close Aug 9, 2016
Toilet Forum discussions Toilet clogged? Please help Jan 26, 2016
Toilet Forum discussions Toilet won't stay unclogged Sep 7, 2015
Toilet Forum discussions Clogged toilet, shower, sink combo May 6, 2015
Toilet Forum discussions New Drake Toilet Clogged Apr 15, 2014
