Doyle670
So I have large house, costs a fortune to heat with fuel oil. Therefore for the last couple years i've used the indoor wood boiler that sits in the basement right next to the furnace. It works great. I use about 12 cords of wood from October-March while burning 0 gallons of fuel oil, then burn approximately 200-300 gallons of fuel oil from March-October.
Although it is nice having the wood boiler in the basement(can load it in my underwear, with no shoes on, etc.), it also is a pain with the smoke and actually getting the wood in the basement. Every now and then when the stove needs to be cleaned it will start smoking pretty good when the door is open to put more wood in. This of course travels right upstairs and usually happens at the worst time(11:00pm on a monday night 5 degrees outside) and can't be cleaned instantly. It is bearable in the house, but just a real nuisance.
So here is my plan. I have an attached 2 car garage that currently has a massive wood stove in it. I want to move the indoor wood boiler to the garage in place of the massive wood stove. In doing so I have to run the supply and return lines to the wood boiler in the garage from the furnace in the basement. It is 49' and I need 2 lines so 100' of pex/copper/cpvc will be enough.
At this point I am preferring pex over copper(because of price - $1600 copper $650 pex) and cpvc(because of many peoples advice). The copper lines that hook to the wood boiler currently are
1-5/8"OD and 1-1/2"ID.
So my first question. I assume I would need to at least stay 1-1/2"ID with the pex I use? So i'm looking at 2" pex that has an inside diameter of 1-5/8". If I go with 1-1/2" pex the inside diameter will be a fraction under 1-1/4"(quite a bit smaller than the current ID of the copper).
Also second question. To connect the pex to the copper, I can simply slide the pex over the copper pipe stub at both locations. But what should I use to clamp/crimp it? I was looking at pex clamps/crimps, but cannot find any clamps that go big enough to use on 2" pex line.
I will probably have some other questions regarding circulator placement for the wood boiler(leave where it is or move near the wood boilder in the garage), but will ask them at a later time. Any help is greatly appreciated by both myself and my "sick of smoke" wife.
