Honeywell Zone System Damper Question
Discussion in 'HVAC Heating & Cooling' started by GrantK, Dec 13, 2007.
  1. GrantK
    GrantK New Member
    Mar 8, 2007
    Pharmaceutical Scientist
    Wisconsin
    I have a 3 zone system on a forced air furnace that uses Honeywell spring return damper actuators. (part#M847D1004) When one of the zones call for heat there is a constant tapping noise coming from the damper actuator, you can see the actuator "clicking" as if it's opening too far or going past a stop. Since this system is a ducted sytem you can hear the tapping all the way upstairs, it's not loud but annoying to say the least. Can these actuators be adjusted and if so does anyone know how? Or should I replace it with a new actuator? (part#M847D1012) Replacing it doesn't look too difficult to do, any insight on replacing one would be helpful also!!! Thanks!!!
  2. Chris75
    Chris75 Electrician
    Aug 12, 2007
    Electrician
    Litchfield, CT
    One of my zone dampers just started doing the same thing you said...
  4. game211
    game211 New Member
    Nov 20, 2008
    same problem
    I have the same problem what did you guys do to solve it??
  5. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    Over time the shaft bearings and the stops wear out. Replace the motor. Follow the instructions, it's a simple jop. don't mix the wires up.
Similar Threads: Honeywell Zone
HVAC Heating & Cooling Adding Zone valves to Honeywell Aquastat L8148J Mar 6, 2014
HVAC Heating & Cooling Honeywell zone control acting strange Nov 28, 2013
HVAC Heating & Cooling Problem with Honeywell hydronic zone valve--replacement the only option? Jan 28, 2013
HVAC Heating & Cooling honeywell true steam vs april air 800 steam humidifier, vs ewc ultrazone May 19, 2012
HVAC Heating & Cooling Honeywell V8043F1093 zone valve Mar 28, 2008
