Honeywell WiFi Thermostat install help
Discussion in 'HVAC Heating & Cooling' started by I26, Jul 4, 2013.
  1. I26
    I26 Member
    Jul 2, 2006
    Reading, Pennsylvania
    I have an older Honeywell thermostat (approx. 6 yrs. old) that I tried to replace with a new Honeywell RTH8580WF model. My current HVAC system is approx 6 yrs old as well (Lennox Signature Series). The current thermostat has a wire going to G, C, R, W1, W2, O. I was using the Alternate wiring key (heat pump system only) in the manual and the problem is that it says "If your old thermostat had separate Y1, W1 and W2 wires, check wifithermostat.com for help". I don't see anything there for help. Not sure what to do now...
    I have a furnace plenum and a heat pump. The plenum has auxiliary heat that kicks on when the heat pump cannot keep up. Can anyone shed some light on where the W1 and W2 wires go?
    Thanks.
  2. DonL
    DonL Jack of all trades Master of one
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    W1 will connect to W-O/B, and W2 will connect to W2-E/AUX.
    Then You need to setup the system type in the thermostat.
    Good Luck.
  4. I26
    I26 Member
    Jul 2, 2006
    Honeywell tech said to tape off the W1 as it is no longer needed. Have not gotten around to try it out. I am slightly afraid a miss wire will hurt the system.
  5. DonL
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    That sounds a bit strange because that would make it use AUX all of the time.
    I guess the Honeywell Tech should know, I was just going by the manual.
    It should not hurt to leave the wire disconnected, but kind of defeats the purpose of having a heat pump.
    Good Luck.
  6. javed
    javed New Member
    Jul 29, 2013
    Brampton, Ontario.
    I have an older Thermostat Terminal connections as in the picture. How will I replace it with the newer ones? oldThermostat.jpg
  7. DonL
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    Look up the model of the Honeywell that you have now.
    Then compare notes to the new one.
    And it may help to start a new thread, instead of adding to this one.
    Good luck.
  8. javed
    javed New Member
    Jul 29, 2013
    Brampton, Ontario.
    Can't figure out the black and the two white ones in the old one. How will I start the new thread?
Similar Threads: Honeywell WiFi
HVAC Heating & Cooling Honeywell 9000 Series Thermostat Installation Help Apr 19, 2016
HVAC Heating & Cooling Lennox to Honeywell Thermostat Jan 9, 2015
HVAC Heating & Cooling Honeywell RTH8500 T-stat Dec 4, 2014
HVAC Heating & Cooling Nest thermostat and honeywell he360a Nov 20, 2014
HVAC Heating & Cooling Honeywell Ventilation System HR200B1005 Nov 20, 2014
