Honeywell Triple Aquastat
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by John456, Jan 20, 2005.
  1. John456
    John456 New Member
    Nov 30, 2004
    :confused: I recently purchased a new home which uses an oil fired burner for heat and hot water. Connected to the burner is a Honeywell Triple Aquastat control L8124A. There are three dials: Hi which is set to 200 dg, low which is set to 180 dg and the differential which is set to about 17. Does anyone know what these mean and whether they are set properly? I want the burner to run efficiently but I think these settings are high. Thanks for your help.
  2. hj
    It has been decades since I have seen one, but if memory is not failing me, the high is the point where the burner shuts off to prevent overheating. Low is the pump's starting point, and differential is how many degrees below the pump starting temperature the boiler temperature will fall before the pump shuts off because the burners cannot keep up with the demand.
Similar Threads: Honeywell Triple
Plumbing Forum, Professional & DIY Advice thermostatic mixing valve (Honeywell AM-1 1070) seized after <3 years? Jul 31, 2016
Plumbing Forum, Professional & DIY Advice Honeywell Aquastat & Outdoor Reset Module Feb 7, 2010
Plumbing Forum, Professional & DIY Advice HoneyWell Braukmann D05 pressure regulator rebuild or replace May 24, 2008
Plumbing Forum, Professional & DIY Advice Honeywell motorized valves Aug 6, 2007
Plumbing Forum, Professional & DIY Advice Replacing Honeywell Braukmann PRV D06 F series Mar 5, 2006
