Home Owner's Reminder
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by hhplumbing, Nov 7, 2012.
  1. hhplumbing
    hhplumbing New Member
    Oct 28, 2012
    Victoria, BC
    Home Owners Reminder/Warning: Winter is getting very close, if not already here in some areas, please remember to remove your garden hoses from your hose bibbs (sediment faucet) to prevent the copper line from splitting.
    I see this all the time! It's an easy mistake to do or even forget about. Most people do know that leaving your garden hose on will cause the line to split in freezing temperatures (even if you have a "Non-Freeze" hose bibb.
    This post is more of a reminder for you the home owner to take off the garden hose BEFORE the freeze.
  2. jimbo
    jimbo Plumber
    A timely reminder, hh Thank you>
  4. hhplumbing
    Oct 28, 2012
    Victoria, BC
    Thanks Jimbo, it's one of those things that just seem to get missed
  5. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    Don't ask me how I learned this!
  6. jadnashua
    It's a good reminder. But, suggest you consider replacing yours with one of the (few) that will drain properly even WITH the hose still on...then, if you forget, it's not an issue!
  7. hhplumbing
    Oct 28, 2012
    Victoria, BC
    That may be an option, but I still say remove the hose. It's easy to do and will save unnecessary work.
Similar Threads: Home Owner's
Plumbing Forum, Professional & DIY Advice Homemade faucet with copper pipe Jan 31, 2016
Plumbing Forum, Professional & DIY Advice Which 1/2" PEX home runs to share with manifold? Jan 24, 2016
Plumbing Forum, Professional & DIY Advice Winterizing a vacant home Jan 18, 2016
Plumbing Forum, Professional & DIY Advice Homeowner thinking of buying either IPC or Uniform Code book Jan 10, 2016
Plumbing Forum, Professional & DIY Advice Adjuster Home Water Pressure - No Regulator Valve In House Dec 5, 2015
