Home Depot or supply house ???
Discussion in 'Toilet Forum discussions' started by 10"rough, Apr 22, 2009.
  1. 10"rough
    10"rough New Member
    Apr 22, 2009
    Wisconsin
    Hey Plumbers out there , Quick question. Is a American Standard Cadat 3 bought at Home Depot the same as one bought from a Plumbing supply house ?
    I've heard some yes and some no.
    Thanks !
  2. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Yea it's the same junk everywhere...
    Not sure if the quality is good anywhere...
    I install Toto!
  4. 10"rough
    10"rough New Member
    Apr 22, 2009
    Wisconsin
    I was set on a Toto Drake , did some checking and I need a 10"rough... could move joist and make it a 12" but not worth it for this house . To bad no 10" Drake.
  5. kingsotall
    kingsotall Plunger/TurdPuncher
    Aug 17, 2008
    Hand copper part cleaned ready to go
    Flagstaff, AZ Sitting on an upside down 5 gallon b
    :D Can always count on Redwood for my morning chuckle. Like hot coffee in the morning.
  6. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    It's your choice. Spend a little time and effort one time now to change the rough-in so you can use a Drake, or spend a little time and effort frequently forever dealing with the AS problems.
  7. Redwood
    Dec 15, 2007
    Service Plumber
    There are plenty of other toilets that Toto makes that fit on a 10" rough...
  8. Redwood
    Dec 15, 2007
    Service Plumber
    What I need to know is if I ever made you laugh so hard that you choked on the coffee and sprayed the monitor with coffee???
    That is the effect I'm trying for!:D
  9. 10"rough
    10"rough New Member
    Apr 22, 2009
    Wisconsin
    I'll take my chances with the AS rather than dealing with floor joist in the way preventing 12".... Besides this is last room to be remodeled in 1942 built home and I'll probably sell sooner than later. Toto Drakes in next one....
  10. Terry
    Aug 17, 2004
    Do you have a true 10" rough?
    I install a lot of the 12" bowls at 10-7/8"
  11. kingsotall
    Aug 17, 2008
    Funny visual and I'm sure it'll happen one of these days. :cool:
  12. 10"rough
    10"rough New Member
    Apr 22, 2009
    Wisconsin
    Yeah , from wall to bolts it's 10-1/4........... I'd be thrilled with 10 -7/8 , Drake would work... No go.
  13. leon wieler
    leon wieler New Member
    Mar 28, 2009
    fix stuff people break
    winnipeg
    10 inch rough in
    I installed a drake in a 11 inch rough in with the back wall sloped considerably toward the toilet. I installed the tank as far to the front of the bowl as possible(the tank bolts are smaller than the hole in the porcelain), angled the flange bolts toward the front as much as allowed, and shimmed the back up one eighth with waterproof wedges. I Tightened the bolts down a little so the bowl would not move and Then I continued shimming the entire toilet right to the front. Finish tightening the bolts and A thin layer of silicone at the bottom and you would never know. The tank clears the wall but barely. I suppose you could add even bigger shims to the back to make more clearance but you still want to make it look like an adult was at work - a huge angle on the toilet makes you look bad even though it might work. If you are concerned about unequal loading on the base you could set the bowl into a mortar mix
Similar Threads: Home Depot
Toilet Forum discussions Best Toilet available from Home Depot or Lowe's? Mar 7, 2016
Toilet Forum discussions Toto toilet bought through Home Depot Jul 31, 2013
Toilet Forum discussions New Delta Prelude Toilets at Home Depot Jan 26, 2013
Toilet Forum discussions Need toilet brand recommendation today. Must be buyable at home depot. Dec 7, 2011
Toilet Forum discussions Does Home Depot "cheapen" their toilets? Jul 6, 2010
