Hole sizes for pipes?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by jwray, Nov 11, 2004.
  1. jwray
    jwray New Member
    Oct 25, 2004
    Virginia
    OK, I'm not a plumber, but I play one at my house evenings and weekends. :D
    This will be a basic question that you can probably answer in your sleep if you are a plumber.
    Getting ready to rough in the plumbing for my remodel, so I thought I'd go buy the necessary drill bits / hole saws to get the job done. So now the question - what sizes and types?
    What size bit / hole saw do you use for each of the supply line sizes:
    1/2"
    3/4"
    1"
    and each of the DWV line sizes:
    1 1/2"
    2"
    3"
    4"
    (BTW supply material will be either copper or CPVC and DWV will be PVC)
    and do you have a preference on the type of "drilling implement", i.e. twist drill/auger bit, speed bit, self feed bit, hole saw for the various size holes?
    Thanks,
    Joel
  2. hj
    holes
    For water lines I use a 1 3/8 for all of them. 1 1/2" pipe a 2"bit , and for a 2" pipe a 2 9/16". All self feed bits.
  4. jwray
    jwray New Member
    Oct 25, 2004
    Virginia
    Supporting the pipe in the hole
    HJ,
    Makes sense. The supply lines will definitely fit through those holes.
    One question. How do you support the supply lines in those holes, especially on horizontal runs?
    Thanks,
    Joel
  5. jimbo
    jimbo Plumber
    Note hj's good comment about using self-feed bits. ( Different brands have different names). If you try to use a hole saw, it will really slow you down.
  6. hj
    anchors
    I use the split plastic rings that fit into the hole and have a "flange" on the outside for two screws.
Similar Threads: Hole sizes
Plumbing Forum, Professional & DIY Advice Whole house drain enzyme? Jan 26, 2017
Plumbing Forum, Professional & DIY Advice Whole House Water Filter HELP...super confused Dec 28, 2016
Plumbing Forum, Professional & DIY Advice Re-Plumbing Whole House Dec 26, 2016
Plumbing Forum, Professional & DIY Advice Pin hole fix above slab Nov 21, 2016
Plumbing Forum, Professional & DIY Advice How to seal bathroom under sink hole &a kitchen marble counter top edges? Nov 18, 2016
