Hole in shower p trap
Discussion in 'Shower & Bathtub Forum & Blog' started by Sumbob, Aug 2, 2014.
  1. Sumbob
    Sumbob New Member
    Aug 2, 2014
    I have a ground floor tiled shower that smells musty all the time.when I looked down the drain I see that there is a hole in the abs at the bottom.do I have to remove tile to fix this?
  2. Terry
    Aug 17, 2004
    Did you vacuum out the water to see? I would love to see a picture of that.
  4. johnfrwhipple
    johnfrwhipple BATHROOM DESIGN & BUILD for both Canada & the US
    Jul 20, 2009
    Design Work World Wide: Bathrooms Vancouver Area
    North Vancouver, BC
    Is it a hole or just a clean out location?
    Some P-Traps look like this.
    [​IMG]
    Others like this.
    [​IMG]
    You might be seeing the clean out and thinking its a hole from the angle you view from.
  5. Sumbob
    Sumbob New Member
    Aug 2, 2014
    There is'nt any water down there,I was assuming that the trap water was leaking out the hole.here's a pic
  6. Terry
    Aug 17, 2004
    No water?
    You will need to fixt it then. You could try dabbing some ABS cement on it in stages. A bit, let that dry an hour, and then hit it again. What do you have to lose?
    I would try cleaning the surface before trying the cement so it can adhere to the ABS fitting. If you can't make it hold water, you're redoing the pan.
  7. Sumbob
    Sumbob New Member
    Aug 2, 2014
    Thank you terry,I appreciate your time and opinion.
  8. hj
    GEt it dry by blowing a hair dryer down the opening. The POUR ABS cement down the drain to fill the hole at the bottom.
Similar Threads: Hole shower
Shower & Bathtub Forum & Blog Plumber didn't center shower drain rough in under the drain hole - how big a problem is this? Jan 28, 2017
Shower & Bathtub Forum & Blog Huge Hole in Shower stall How to Repair without purchasing new stall Dec 3, 2016
Shower & Bathtub Forum & Blog Shower valve hole in shower is BIG ... 7.5" Jun 3, 2015
Shower & Bathtub Forum & Blog Delta Shower Faucet in Fiberglass Shower; Hole Size? Remove Plaster Guard? Jan 31, 2015
Shower & Bathtub Forum & Blog Shower Drain Weep Hole Research - by the NTCA and Cecil Hunt 2014 Jun 11, 2014
