Hole in ABS pipe
Discussion in 'Shower & Bathtub Forum & Blog' started by sk8ter, Oct 15, 2009.
  1. sk8ter
    sk8ter New Member
    Oct 15, 2009
    Canada
    Hi,
    As I was trying to install the new shower base in the basement i drilled around the rough-in 1-1/2" pipe then cut the concrete by using a chisel.
    When the area was exposed, I found that I drilled into the horizontal pipe as shown in the picture.
    IS there a way to plug/repair/patch the hole (approx. 1/4") other than cut more concrete and cut and replace the whole things there?
    Thanks
  2. sk8ter
    sk8ter New Member
    Oct 15, 2009
    Canada
  4. johnjh2o1
    johnjh2o1 Plumbing Contractor for 49 years
    Aug 9, 2009
    Retired
    Florida
    First a shower drain should be 2". It looks like the hole is in the top side of the trap. Cut out the rest of the concrete and replace the trap. You should really change the line to 2".
    John
  5. jimbo
    jimbo Plumber
    I am not averse to doing a billy mays job when appropriate. This time, it is definitely not appropriate. Tub/shower drains are prone to hair issues. The slightest discontinuity on the inside of the pipe will tend to grab and agglomerate hair. Being under the slab, and under your soon to be brand new shower, do you want to do anything which has fair risk of not surviving LONG TERM?? Get out the jack hammer!
    [​IMG]
  6. hj
    hole
    If the hole were in a straight section of piping there are several ways to fix it. Your hole is on a curved section next to a bell hub, so there is NO WAY to do a proper repair on it. If the pipe is 1 1/2", then you already have a improper drain for a shower, besides having a hole in it.
  7. sk8ter
    sk8ter New Member
    Oct 15, 2009
    Canada
    Thanks guys.
    I followed your advice and all are good.
Similar Threads: Hole pipe
Shower & Bathtub Forum & Blog concrete foundation hole? where are the pipes? Aug 6, 2006
Shower & Bathtub Forum & Blog Does it make sense to do a whole floor in fiberglass? Feb 4, 2017
Shower & Bathtub Forum & Blog Plumber didn't center shower drain rough in under the drain hole - how big a problem is this? Jan 28, 2017
Shower & Bathtub Forum & Blog Huge Hole in Shower stall How to Repair without purchasing new stall Dec 3, 2016
Shower & Bathtub Forum & Blog New tub faucet - old holes don't line up. What to do? Jul 14, 2016
