If you have a garage that you converted into a living area as a guest apartment (occasional use) and you were upfront with any potential new owners about your intentions, would it be possible to have a holding tank for waste and simply have it professionally pumped when it needed it?
The tank would set in a hole out side (but not necessarily buried) and the outgoing drain line would be above the highest water level (like a septic tank). The tank itself could hopefully handle any freeze/thaw and measures would be taken to insulate the outgoing drain pipe.
I don't see why you couldn't do this, chances are any "guests" would be very infrequent.
My concern is with an inspector if I sell the home. If I told him and the new owners about it and my intentions of NON daily use would it be accepted? And if the work was professionally done.
No way I want to do a new septic tank for something that may get used a few times a month at most.
If I can't do this, going to setup a composting toilet. It's just that I already have a nice toilet already installed
and plumbed. -- thanks
