holding tank pressure valve question
Discussion in 'Pumps and Tanks Well Forum & Blog' started by Nevada7, Jul 16, 2005.
  1. Nevada7
    Nevada7 New Member
    Jun 28, 2005
    After my holding tank became waterlogged and having fixed that, I started to notice that the pump would not kick on until the pressure got lower and lower.
    Last night I happened to go into the garage after hearing 'air' noise.
    The sprinklers had kicked on and the pressure was down to 20 pounds. Air was blowing out the bottom of the pressure valve and I could hear the pump coming on and off. I stopped the air blowing with my finger, then the pump kicked on and the air stopped blowing out of the valve.
    Does this sound like a new pressure valve is in order?
    Thanks,
    David
  2. speedbump
    speedbump New Member
    Jul 15, 2005
    Water well and pump tech.
    Riverview, Fl.
    Hi David,
    Define pressure valve please.
    What are your pressure switch settings?
    bob...
Similar Threads: holding tank
Pumps and Tanks Well Forum & Blog My Scenario - Adding Second Holding Tank Apr 20, 2015
Pumps and Tanks Well Forum & Blog 1200 gallon holding tank emtied Mar 16, 2014
Pumps and Tanks Well Forum & Blog Bladder tank and holding tank Nov 14, 2013
Pumps and Tanks Well Forum & Blog Well running dry even after 2 holding tanks installed???? Nov 3, 2013
Pumps and Tanks Well Forum & Blog UT-80 Tank not holding water? Micronizer or AVC? Jul 23, 2013
