Hissing Korky
Discussion in 'Toilet Forum discussions' started by ICR, May 13, 2011.
  1. ICR
    ICR New Member
    May 13, 2011
    I searched the Korky site, and the internet in general and could not find the answer to the hissing and leaking Korky valve, so I thought I'd pass on my solution.
    Certainly if the red diaphragm is bad it will leak but after replacing that the leak is still there? On my units the leak was coming around the CENTER TUBE. There is an o-ring on the main body of the unit, through which the CENTER TUBE inserts. In my case the o-ring lost its elasticity and caused a leak.
    Since these leaking or noisy Korky valves are so common I'm surprised I did not encounter any mention of that o-ring. That o-ring certainly is important because it has to hold back the supply line pressure.
Similar Threads: Hissing Korky
Toilet Forum discussions Water use - hissing G-Max Korky 528 fill valve - Quiet Fill Nov 14, 2009
Toilet Forum discussions Intermittent hissing noise from Toto fill valve even after replacements Jan 11, 2017
Toilet Forum discussions Toto toilet making bursts of hissing air noise when flushing Dec 1, 2015
Toilet Forum discussions Toto Drake GMAX Fill Valve Hissing Feb 4, 2015
Toilet Forum discussions Geberit system hissing - internet says might be a diaphragm? Feb 2, 2015
