Hills and backflow preventers.
Discussion in 'Irrigation / Sprinkler Forum' started by drick, Jul 26, 2010.
  1. drick
    drick In the Trades
    May 16, 2008
    I have a 7 foot hill that rises up behind my house. I will be landscaping it soon and I'd like to add sprinklers. I already have an irrigation system for my front yard and would like to tap into it. Can I use my existing backflow preventer which is essentially at the bottom of the hill? Or do I have to pipe the water to the top of the hill, install the backflow preventer there, and then go out to my zones on the hill?
    I recall reading somewhere that the backflow preventer has to be at the highest spot in your irrigation system, but now I can't seem to find that reference.
    -rick
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    There are several different kinds of BFP. Some do have to be at the highest point in the system, but better ones (also more expensive) do not. You should check with your city to see what their requirements are. I use a Wilkins Double Check BFP that is installed in a plastic box below grade. I am required to have it certified each year by a licensed inspector. All BFP should be inspected yearly because they do wear out and require repairs occasionally, but some communities ignore the EPA rules.
  4. hj
    ALL backflow preventers SHOULD be installed above grade, if they have a "vent" on them. A backpressure on any, other than a RPPBFP version which can stand a 5# backpressure before venting, have to be above the highest point in the system, otherwise they "drain" out everytime the water is turned off, and theoretically could cause contamination of the potable water system. Most areas do NOT approve a simple "double check BFP" without a vent, since there is no indication when they fail or are failing.
  5. Fireguy97
    Fireguy97 Irrigation Contractor
    Mar 21, 2010
    Irrigation Contractor / Certified Backflow Assembl
    Kamloops, in Beautiful British Col
    Again check with your municipality. Some areas approve a Pressure Vaccume Breaker (PVB), some don't because they don't handle back pressure, just back-siphonage.
    You don't mention where you are, do it's difficult to help any more.
    And by the way, a double check valve backflow assembly (DCVA) doesn't have a vent port. If it did, It wouldn't be a DCVA, it would be a reduced pressure principle backflow assembly (RPBA).
    Mick
Similar Threads: Hills backflow
Irrigation / Sprinkler Forum Leaking Watts Backflow Preventer Oct 12, 2015
Irrigation / Sprinkler Forum Pressure vacuum breaker backflow prevent or always engaging May 21, 2015
Irrigation / Sprinkler Forum Not getting water through backflow preventer May 17, 2015
Irrigation / Sprinkler Forum Backflow device for greywater changeover device Apr 29, 2015
Irrigation / Sprinkler Forum What type of backflow device is this? Apr 4, 2015
