Higher pressure than before.
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by OhioBuck77, May 29, 2011.
  1. OhioBuck77
    OhioBuck77 New Member
    May 29, 2011
    Southern Ohio
    I just installed a new water heater and a new thermal expansion tank and my water pressure is a good bit higher than it was before. This doesn't seem right to me. But I have never installed a thermal expansion tank before so I really don't know. Any idea what is going on? Any answers would be appreciated!!
  2. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    The dielectric nipples on the old water heater may have been occluded lowering the flow, or maybe the valve you shut off to do the work was not fully open...
    If you have any concerns about your work post a picture...
  4. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    I very much doubt the expansion tank would have anything to do with the pressure difference. They are too small to provide pressure storage.
    Perhaps the old water heater was gunked up with hard water deposit reducing the flow.
    Perhaps the temperature on the new tank is higher so there is more cold added to the mix. I deliberately set the temp on the water heater so that the shower temp is just right with both hot and cold full open. That provides the most flow which translates to more pressure from the shower head.
  5. hj
    Expansion tanks do NOT change the pressure, they just respond to the pressure you have, so either something else has occurred, or your perception is faulty.
  6. Terry
    Aug 17, 2004
    Pressure or volume?
    I always notice that there is more usable hot water from the faucets when an expansion tank is installed.
    They buffer the input when a faucet is opened elsewhere in the system. I wouldn't personally have a home without an expansion tank.
  7. Redwood
    Dec 15, 2007
    Service Plumber
    Oh jeez... Here comes BallValve...
  8. Terry
    Aug 17, 2004
    Ballvalve lives in a cave.
    His water comes through a spring that weeps out from a crack in the ground.
    Ballvalve fetching wood to heat his water.
  9. DonL
    DonL Jack of all trades Master of one
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    LOL, That is funny, I don't care who You are...
    OhioBuck77, it sounds like you have it working normal.
  10. Neanderthal Man
    Neanderthal Man The Cave Man
    May 30, 2011
    It's So Easy A Cave Man Could Figure It Out
    In a Cave
    Hey Don't be picking on my little brother.
    It isn't easy being a Cave Man.
    Especially since those damn Geico Commercials.
    We have feelings you know.
  11. DonL
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    Is that why they canceled your TV show ?
    Did not mean to poke fun.
    Your brother is cool.
  12. Neanderthal Man
    May 30, 2011
    In a Cave
    No the director said that Ballvalve couldn't take direction.
    And then he shaved thinking it would make it easier to pick up the babes.
    It was all over after that the shooting delays made them mad.
  13. Redwood
    Dec 15, 2007
    Service Plumber
    I can understand that... He does seem a bit headstrong...
  14. PlumbersSanJose
    PlumbersSanJose San Jose Plumber
    May 30, 2011
    San Jose Plumber
    San Jose
    Pressure is always easy to figure out. I think the first answer regarding build up in the pipes or the valve not being turned on all of the way is the best answer.
  15. OhioBuck77
    May 29, 2011
    Southern Ohio
    Thanx for your input I think it is okay it has been almost 6 days and everything seems to be doing fine. The pressure starts out harder and then dies down to close to where was before I installed the tank. You have a great forum here. Thanks again!!
  16. LLigetfa
    Feb 6, 2011
    NW Ontario, Canada
    The expansion tank has a small amount of "storage" that quickly draws down. That in and of itself, indicates that there is a flow restriction somewhere upstream.
Similar Threads: Higher pressure
Plumbing Forum, Professional & DIY Advice Installed expansion tank now pressure is higher? Aug 23, 2016
Plumbing Forum, Professional & DIY Advice Do thermostatic valves supply higher GPM than balanced pressure units? Jul 2, 2008
Plumbing Forum, Professional & DIY Advice PEX for higher pressures May 12, 2007
Plumbing Forum, Professional & DIY Advice tannis filter issues with higher pressure Feb 21, 2006
Plumbing Forum, Professional & DIY Advice Replacing a backup Zoeller 507 with something higher in capacity? Jan 3, 2017
