High water pressure
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by lennyk, Jan 31, 2010.
  1. lennyk
    lennyk New Member
    Sep 30, 2007
    Port-of-Spain
    Hello,
    I have a house in a neighbourhood with very high water pressure 100+psi.
    A pressure reducing valve was installed and appears to work once there is water flowing,
    this was tested at various settings and looking at the gauge.
    However when there is no water used in the house/flowing, the pressure rises to the 100+psi.
    Are PRV valves supposed to work like this or is there a problem with this valve ?
    Thanks,
    L
  2. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    The PRV limits pressure coming into the house. If the pressure is building from the water heater, the PRV is not at fault. Do you have a working expansion tank?
  4. jadnashua
    WIth a PRV, you need a working expansion tank so the WH operation which causes the water to expand when it works, has someplace to go. If that isn't the reason for the pressure rising, then the PRV is defective and needs to be replaced or rebuilt. It could be letting pressure rise because of a bad internal seal, dirt, or other defect.
  5. lennyk
    lennyk New Member
    Sep 30, 2007
    Port-of-Spain
    yes, there is no expansion tank, should I just have one installed nearest to the cold input of the water heater ?
    Also are expansion tanks the same as water pump pressure tanks ?
  6. lennyk
    lennyk New Member
    Sep 30, 2007
    Port-of-Spain
    I ran some tests tonight with a pressure gauge, both with the water heater on and off.
    The heater is not the problem as the pressure creeped up to max on the gauge.
    Good thing is that the mains is split into two -
    one for a tank supply which feeds a pump in case water mains supply is off
    and secondly into the house via the PRV.
    I removed the PRV and shut off that supply, I think I am going to leave it that way and have one less
    thing to go bad and just run the house off the pump supply and let the float valves in the tanks take the high pressure instead.
Similar Threads: High water
Plumbing Forum, Professional & DIY Advice Knocking pipe and water "spitting" in highest shower in house Nov 1, 2016
Plumbing Forum, Professional & DIY Advice Is there a special shut-off for higher than WH temp water? Sep 14, 2016
Plumbing Forum, Professional & DIY Advice Best option to filter water with high Al and Iron, and turbidity Sep 6, 2016
Plumbing Forum, Professional & DIY Advice What is this fitting? → Pressure relief valve. → Weird pressure problems. → High water pressure! Jun 4, 2016
Plumbing Forum, Professional & DIY Advice Water pressure too high after replacing water pressure regulating valve Apr 14, 2016
