High Water Pressure Spikes on Well with Pressure Tanks
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by RayMan, Jan 30, 2010.
  1. RayMan
    RayMan Shared Well Services
    Jan 23, 2010
    Self Employed
    Arizona
    What would cause High Water Pressure Spiking at the house. I put a pressure gauge on the hose bib and its been on for three days now. The gauge has a needle that shows the highest water pressure reached, the first day the highest pressure was 65 psi the next day was 80 psi and today it reads 116 psi. as the highest pressure. The static pressure has remained at about 45 psi and the water pressure recovers to 42 psi with an open line in the house. There is no air in the lines.
    The pressure control switch is a 30/50 psi for 5 pressure tanks and the static pressure reading on the gauge in the well house has varied, it was 48 psi then 53 psi and the highest I read was 57 psi. There is a 5HP Submersible Jacuzzi Pump in the ground. The last time the pressure tanks were inspected they wrote the psi on each tank 30, 25, 25,25,30. They are 86 gallon Proline bladder tanks.
    Thank You For Any Explanation!! :confused:
  2. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    Clean out the line running to the pressure switch or the pressure switch is bad.
  4. Gary Slusser
    Retired
    It may be more likely that there are check valves and water heaters are building excessive pressure overnight. Or there is some filter etc. reducing flow through them.
  5. ballvalve
    Dec 28, 2009
    northfork, california
    Water hammer would cause short spikes. If the house pressure was at 116 for more than a moment or two, You would start finding leaks at supplies, and the shower would drill holes in your head.
    Nix the recording gauge and just have the homeowner check a normal gauge installed inside the house somewhere. Move the "recording" gauge to the pumphouse to rule out switch issues.
    Water heaters in my houses with pressure regulaters and incorporated check valves have never caused any pressure rise over2 or 3 psi.
Similar Threads: High Water
Pumps and Tanks Well Forum & Blog. Water is life. HIGH Iron in Manganese in well water! Recommendations? Nov 10, 2013
Pumps and Tanks Well Forum & Blog. Water is life. high iron well water with greensand filter Nov 12, 2012
Pumps and Tanks Well Forum & Blog. Water is life. Looking for float valves in cistern that can withstand high water pressure and gas? Oct 12, 2012
Pumps and Tanks Well Forum & Blog. Water is life. High pressure water pumping? Aug 18, 2012
Pumps and Tanks Well Forum & Blog. Water is life. High iron in water questions. Jun 28, 2009
