High water pressure outside; low inside house
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by cepperson3, Sep 4, 2010.
  1. cepperson3
    cepperson3 New Member
    Sep 4, 2010
    Charlotte, NC
    I have been searching for an answer to my unique problem and I hope someone can help. I have extremely high water pressure on the outside front hose bib (115 PSI). I've already had to replace part of the water pipe coming in from the street probably because of the high pressure. The plumber who did this could not figure out why the pressure is so high outside but so low everywhere inside. He said if I put a pressure regulator valve on that it would probably reduce the inside pressure even more. Anyone have any ideas? Thanks!
  2. jimbo
    jimbo Plumber
    My first thought was that your pressure regulator is defective. Your symptoms are classic for that. But you seem to indicate there isn't one. I would look for one somewhere, because otherwise you need to call in Dick Tracy!
  4. Ian Gills
    Jul 24, 2007
    USA
    Is the pressure low or the flow low inside? Don't confuse the two.
    Did he measure the pressure inside as well?
    Low flow can be caused by pipes that are narrow.
  5. cepperson3
    Sep 4, 2010
    Charlotte, NC
    I don't remember if he measured the pressure inside, so I guess the flow is low.
  6. cepperson3
    Sep 4, 2010
    Charlotte, NC
    The plumber did not see a pressure regulator installed. I'm thinking of calling another plumber for a second opinion. Thanks.
  7. cepperson3
    Sep 4, 2010
    Charlotte, NC
  8. Terry
    Aug 17, 2004
    The PRV may not include the hosebib. That can happen. I would trace the lines back and see if I could spot an old PRV, which may need replacement.
Similar Threads: High water
Plumbing Forum, Professional & DIY Advice Knocking pipe and water "spitting" in highest shower in house Nov 1, 2016
Plumbing Forum, Professional & DIY Advice Is there a special shut-off for higher than WH temp water? Sep 14, 2016
Plumbing Forum, Professional & DIY Advice Best option to filter water with high Al and Iron, and turbidity Sep 6, 2016
Plumbing Forum, Professional & DIY Advice What is this fitting? → Pressure relief valve. → Weird pressure problems. → High water pressure! Jun 4, 2016
Plumbing Forum, Professional & DIY Advice Water pressure too high after replacing water pressure regulating valve Apr 14, 2016
