High PH & Hard Water
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by macdarty, Apr 9, 2008.
  1. macdarty
    macdarty New Member
    Apr 9, 2008
    I have a PH of 9.3 SU and a Hardness of 3.6 mg/L. Culligan had installed a chlorine injection & carbon bed to remove the sulfer smell but our plumbing is repeatedly being repaired ( shower valves . Culligan now is recomending a acid injection system to lower the PH and remove suspended sulfer ? any coments ??
    thanks macdarty
  2. speedbump
    speedbump New Member
    Jul 15, 2005
    Water well and pump tech.
    Riverview, Fl.
    Are you really willing to give them a second chance???
    bob...
  4. macdarty
    macdarty New Member
    Apr 9, 2008
    reply
    good point but the well installer want to sell a water softner but i don't have hard water .. it just acts like it.
  5. Gary Slusser
    Retired
    What is the raw water pH or is this 9.3 pH from before the equipment?
    The acceptable pH is from 6.5-8.5. What is the high pH doing to your plumbing? Or how do you know it is the pH that is causing problems?
    When you use chlorine, it raises the pH. Is there too much chlorine being injected?
    The only way to reduce pH is with acid.
  6. macdarty
    macdarty New Member
    Apr 9, 2008
    Ph
    the test was done post treatment not at well head. i do suspect the carbon bed needs rebuilding ... culligan advised us to increase chlorine until we no longer had a sulfer smell .. our problem is pitted fixtures ,clogged shower valves. section of plastic plumbing have white powder or hard black build up at copper elbows.
  7. Gary Slusser
    Retired
    You need a test on the raw water to be able to compare the two readings to see if the chlorination is causing the high pH.
  8. speedbump
    Jul 15, 2005
    Riverview, Fl.
    That's one of many reasons I discourage the use of Chlorine.
    bob...
  9. Gary Slusser
    Retired
    Mac, are you seeing that stuff on the outside of the fixtures and pipes or inside them?
    Do you smell chlorine in your water?
  10. macdarty
    macdarty New Member
    Apr 9, 2008
    reply
    I have green mineral deposits on chrome shower heads & rush on cheap chrome soap holders. Pitting on chrome drain heads. When we moved in the plastic plumbing had black hard rock at elbows that blocked all flow to several bathrooms. Now were seeing off white power in the whole house filter, elbows, tolit tanks, and shower mixing valves. Cullligan thinks it is sulfer in suspension.
    No we do not smell chlorine. I'm buying a chlorine & PH tester while the well people will test inside and at the well again for free.
    mac
  11. Gary Slusser
    Retired
    That doesn't mean there is something in the water causing those problems with the fixtures, it could be the quality of those parts or cleansers and soaps used.
    Green is usually corroded brass or copper deposits.
    The stuff in the pipes is definitely caused by the water and probably is stained water hardness scale.
Similar Threads: High Hard
Plumbing Forum, Professional & DIY Advice Very hard water, iron, manganese, sulfates and high TDS ADVICE WANTED Jul 4, 2014
Plumbing Forum, Professional & DIY Advice Toilet flange too high? Feb 16, 2017
Plumbing Forum, Professional & DIY Advice High Wall Drain, New Sink & Disposal Dilemma Feb 15, 2017
Plumbing Forum, Professional & DIY Advice New kitchen, new sink, drain too high! Feb 14, 2017
Plumbing Forum, Professional & DIY Advice Replacing a backup Zoeller 507 with something higher in capacity? Jan 3, 2017
