High Limit Question
Discussion in 'Water Heater Forum, Tanks' started by shawninolympia, Dec 24, 2009.
  1. shawninolympia
    shawninolympia Computer Repair
    Dec 24, 2009
    Olympia
    Merry Christmas Everyone!
    So I ran to the store today and came home and my wife said she smelled something burning in my daughters room. I went in, checked everything I could and I could not find the source of the smell. For some reason, I decided to check the hotwater tank in the closet behind a false wall. The smell was coming from there. I took off the top cover where the "high limit" is and there is melted and burned plastic. Yes I turned off the breakers and tested to make sure no power was still flowing to it before I did anything. Do you think I should just replace the high limit and if so where would I go to buy one. Thanks for any help! What a time for the tank to not work! Merry Christmas!
    Shawn
    Olympia, Wa
  2. Doherty Plumbing
    Doherty Plumbing Journeyman & Gas Fitter
    Jun 22, 2009
    Red Seal Journeyman Plumber & Licensed Gas Fitter
    Penticton, BC
    Replace high limit and the thermostats.
  4. hj
    high limit
    The replacement "upper" thermostat will come with the high limit. You must have had a loose wire which created high resistance and heat to melt it. You will probably have to shorten, or replace some wires, to eliminate the melted portions.
  5. shawninolympia
    Dec 24, 2009
    Olympia
    Thank you
    I will give that a try tomorrow! I don't think many places are open today! :eek:) Again, thank you for what you do and if I don't think I can handle the job I will be calling a professional. Merry Christmas!
  6. Master Plumber Mark
    Master Plumber Mark Master Plumber
    Feb 6, 2005
    Sensitivity trainer...healey-feeley.....
    change it all
    usually the high limit fails due to a problem in
    the system, a shorted out element....
    I suggest you take a good look at the elements...
    It really dont cost much more to
    change out everything both upper and lower
    t-stats and elements just to be safe
  7. shawninolympia
    Dec 24, 2009
    Olympia
    Question
    I build computers for a living. I'm not a plumber. I do have alot of mechanical ability so I know I can do this and if I don't think I can I will call someone. I do have one question. In order to change everything like you say, I have to drain the tank correct? Thanks
  8. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    If you are changing elements the tank has to be drained.
    It does not have to be drained to change the ECO and Thermostat.
  9. Master Plumber Mark
    Feb 6, 2005
    yes drain the tank
    its wise to drain the tank to change the elements,
    then look inside the bottom element to see how built up
    the sediment and lime might be inside the heater...
    scrape that out if necessary
  10. Terry
    Aug 17, 2004
    If the tank is over ten years old, you may want to consider replacement on the tank too.
    Water heaters tend to run in the 10 to 20 year range for life expectancy.
    Though, that's an average, not a promise.
  11. Cass
    Cass Plumber
    Nov 12, 2005
    I'm not sure how you do it but I can't remember the last time I drained a water heater to change an element...
  12. Redwood
    Dec 15, 2007
    Service Plumber
    I do it on the quick too but I would advise to home handyman type to drain a water heater....:eek:
Similar Threads: High Limit
Water Heater Forum, Tanks Hot Water Heater High Limit Switch Continualy Trips Apr 18, 2010
Water Heater Forum, Tanks Electric water heater keeps tripping high limit. Nov 9, 2009
Water Heater Forum, Tanks New Water Heater - Scale, High pH / Alkalinity Yesterday at 6:41 AM
Water Heater Forum, Tanks High Efficiency Water Heater vs Boiler with Indirect Feb 11, 2016
Water Heater Forum, Tanks Rheem tankless gas water heater always starts on HIGH! Jan 19, 2016
