high flow kitchen faucet
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Amopower, Jan 23, 2007.
  1. Amopower
    Amopower Member
    Sep 14, 2006
    Virginia Beach
    What sorts of GPM would a high flow kitchen faucet tend to output? 2.2gpm? more? I thought that mine was rather slow, but I measured it today and it was around 2 gpm or a little more. I guess I am lookign for something even higher. Any ideas?
    Thanks
  2. Dunbar Plumbing
    Dunbar Plumbing Master Plumber
    Apr 18, 2005
    Service Plumber, Outdoor Temperature Relief Owner
    Removing the flow restrictor will help with that problem but what is the reason? Moen faucets are notorious for poor water flow on kitchen sink faucets. Especially the 875 series.
  4. Amopower
    Amopower Member
    Sep 14, 2006
    Virginia Beach
    I just want a stronger flow rate. If I am filling up a gallon jug or a large pot, I don't want to have to wait forever. If the flow is too fast, I'd rather have the power to turn the handle down a little, than to be stuck with a maximum rate.
    I read though that there is a 2.2GPM limit on faucets nowadays, so maybe there's not much I can do. Ever go to a gas station and have the guy next to you also fill up, and notice the lovely slowwww rate the gas comes out? That's what it feels like.
    I do have a Moen that has a pullout sprayer. You guessed right!
    My water pressure is 60 psi on the nose.
  5. jimbo
    jimbo Plumber
    2.2 GPM is the federally mandated max rate for faucets.
  6. TedL
    TedL New Member
    Sep 17, 2006
    NY Capital District
    Most faucets rely on a flow restrictor included as part of the aerator to achieve that low flow rate. It usually is a disk with a small hole in the center, which can be easily removed.
  7. Amopower
    Amopower Member
    Sep 14, 2006
    Virginia Beach
    I noticed the flow is less if I am on full hot or full cold. In the middle is the best flow. I suppose that is normal behavior though.
Similar Threads: high flow
Plumbing Forum, Professional & DIY Advice Higher temperature water heater overflow valve? Jan 30, 2013
Plumbing Forum, Professional & DIY Advice high temp flow reducer Jul 15, 2009
Plumbing Forum, Professional & DIY Advice high flow rate pressure regulator? Jul 7, 2009
Plumbing Forum, Professional & DIY Advice BRIZO high flow rough in Dec 16, 2007
Plumbing Forum, Professional & DIY Advice leaky backflow preventer & high water pressure Nov 9, 2007
