High Boiler Pressure
Discussion in 'Boiler Forum' started by E_Chorn, Sep 26, 2011.
  1. E_Chorn
    E_Chorn New Member
    Sep 26, 2011
    Calgary, AB
    Since I'm pretty new to the DIY'ing, I was hoping someone would be able to help me out...
    I have in-floor heating as my primary heating system, which also heats my DHW through an indirect. The boiler has been sitting around 33-35psi for the last little while, causing my PRV to release water on a semi-regular basis. I originally thought my expansion tank was the issue. It's 9 years old and was full of water. I replaced it a couple weeks ago, and the boiler pressure evened out at around 20psi.
    Now, about 2 1/2 weeks later, my PRV is leaking again. Was hoping it was just a faulty valve after the workout it got before, unfortunately I checked my boiler, and the pressure is back up to ~33-35psi. Any thoughts or ideas on what could be going wrong here?
  2. Tom Sawyer
    Tom Sawyer In the Trades
    Nov 29, 2010
    Maine
    Drop the pressure to 15 lbs and shut off the water feed. If the pressure climbs you have an expansion tank issue. If it falls, you have a leak.
  4. E_Chorn
    E_Chorn New Member
    Sep 26, 2011
    Calgary, AB
    I can't seem to get the pressure to drop... before I could get it to drop by releasing water through the PRV. Now it's staying consistent at above 30... any suggestions?
    Also; the tank was pressurized at 15 when I bought it. Checked on it now, and the pressure on the tank is sitting at around 26
  5. jadnashua
    When the system is closed, the tank will read the same as the water pressure. You can only preset that pressure when there's no water pressure on the other side. Did you shut the autofill valve out of the circuit? If it is leaking, it will keep the pressure high. If your water pressure gauge is not reading the same as the expansion tank, then one or the other gauges is wrong. Other causes of high pressure could be a leak in the IWH heat exchanger.
  6. E_Chorn
    E_Chorn New Member
    Sep 26, 2011
    Calgary, AB
    I shut the autofill off, and the pressure did come down a little bit. Is this pointing toward a leak in the system like Tom Sawyer indicated above?
    Also, I just had the indirect hot water tank replaced about 6 months ago. You think there may be a leak in the new tank?
  7. Tom Sawyer
    Nov 29, 2010
    Maine
    Very possible that there is a leak between the coil in the indirect and the potable supply. To test. Shut off boiler feed , drop the pressure in the boiler to 15 lbs and see if it climbs again. If it does, the only place it can be getting pressure is through the indirect's coil.
  8. jadnashua
    What kind of valve is it that disconnects the autofill? If it's not a ball valve, that could be leaking. The pressure will change slightly based on the temperature of the water in the system...the expansion tank helps to moderate that quite a bit, but it can still change (but not by much).
  9. BadgerBoilerMN
    BadgerBoilerMN Hydronic Heating Designer
    Mar 4, 2011
    hydronic heating designer/contractor
    Minneapolis
    If you had your indirect changed out, you know a professional. There is your answer.
  10. E_Chorn
    E_Chorn New Member
    Sep 26, 2011
    Calgary, AB
    It's actually a cross connection (Watts 009) and a regulator (Watts 1156F) that are controlling the water entering into the system.
    I'm leaning more towards there being a leak somewhere in the system. After I turn off the supply, the system seems to lose water, and fills up with air. I'm really hoping it's not a pipe in one of the zones, but I'm thinking I should start shutting off zones (there are 4) one at a time and testing out whether the system continues to take on air with each of them shut off.
  11. E_Chorn
    E_Chorn New Member
    Sep 26, 2011
    Calgary, AB
    I got hosed by the company that changed out my indirect. I would rather not go back to them.
Similar Threads: High Boiler
Boiler Forum Creeping Boiler Pressure! Too High Help! May 4, 2016
Boiler Forum Weil McLane boiler keeps shutting off, pressure too high Nov 14, 2013
Boiler Forum HIgh Effiency Condesing Boilers: Experienced Installer in Westchester NY? Aug 12, 2013
Boiler Forum pH neutralizing media on high efficiency boiler Aug 25, 2012
Boiler Forum High and Low Pressure boiler resources Jul 31, 2012
