Help with whole faucet swiveling instead of just the top
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Al Wet, Jul 12, 2013.
  1. Al Wet
    Al Wet New Member
    Feb 17, 2013
    Arkansas
    We've tried grabbing the bottom of the faucet from below but so far we haven't been able to tighten it enough to keep the whole thing from swiveling. I put a video on Youtube showing what it's doing. It's here: http://youtu.be/HWURi7hnZck
    There also is a very small bit of water coming out at the bottom of the base when I wiggle it.
    The bottom part of the faucet is stuck or frozen. Any advice on what a more experienced person would do to solve this would be much appreciated . For example... the right tool to grab hold of that nut underneath or how to get the top part unfrozen and grab hold of it to tighten. Thanks
  2. Terry
    Aug 17, 2004
    You may need a basin wrench on that.
  4. hj
    A basin wrench, or a hammer and chisel to "drift" the nut tight. BUT, you may have a situation where the spout is frozen to the valve body and when you tighten the nut the spout will NOT rotate. When that happens the best solution is usually to contact the manufacturer and have him send a new faucet if it has a "lifetime" warranty.
  5. Al Wet
    Al Wet New Member
    Feb 17, 2013
    Arkansas
    Thanks for the replies. There's so little clearance by that nut the basin wrench doesn't get a firm grip. The top part of the faucet doesn't seem to have any brand marking that we can see. Any secret places where it might show it? In terms of the swiveling it seems to be pretty much frozen. Could it be pried at all and lubrication sprayed?
  6. hj
    quote; Could it be pried at all and lubrication sprayed?
    You can try, but my experience has been that it either does not work or it happens again fairly quickly.
  7. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    I would start with a complete removal and disassembly to determine where and why it is binding. My guess is that harsh cleansers may have caused corrosion inside the unit. Once you determine the cause, then you can decide whether or not it can be mitigated or replaced.
    When reinstalling, consider adding O-rings or neoprene washers for friction and a larger metal washer on the underside.
  8. Al Wet
    Al Wet New Member
    Feb 17, 2013
    Arkansas
    An easy fix doesn't seem to be in the cards. Thanks for the suggestions.
  9. hj
    IT is a KWC faucet, which has a 5 year guarantee, but you either have to contact the factory, or the supply house which furnished it. They may also want an invoice showing when it was purchased or installed.If it can be repaired, you basically have to take the entire faucet apart to free up the rotating spout.
Similar Threads: Help whole
Plumbing Forum, Professional & DIY Advice Whole House Water Filter HELP...super confused Dec 28, 2016
Plumbing Forum, Professional & DIY Advice Help with a whole house filter system Feb 21, 2007
Plumbing Forum, Professional & DIY Advice Toilet 16" rough in help Wednesday at 7:55 PM
Plumbing Forum, Professional & DIY Advice Fleck 5600SXT Program help Mar 21, 2017
Plumbing Forum, Professional & DIY Advice Stuck U-Pipe slip-nut help Mar 20, 2017
