MJB
After running a cycle in washing machine, water was dripping onto the clothes only when we used hot. Then machine would not work at all on hot. It just buzzed. I tried to clean vents on water inlet valve. It seemed to work. Hot water was back working, but after a few minutes the hot water pipe right above the machine starts banging really loud and will not stop unless you shut it off or switch to cold.
I then replaced the water inlet valve with a new one, but I am still having the problem with the really loud banging pipe which means we have not been able to use hot water.
I'm now wondering if the issue is with the washing machine valve. It's a Symmons #W-400. Should I replace it or could there be another problem I'm missing?
Thanks in advance!
Thanks in advance!
