Help with tub to shower conversion, water line reroute
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by loudgonzo, Jan 7, 2014.
  1. loudgonzo
    loudgonzo New Member
    Jan 7, 2014
    Wylie, Tx
    Hi guys,
    I was suggest by a member on another forum to ask about a tub to shower conversion I am doing here. I removed the old "original" tub and found the builder routed the water supply line outside the studs, and now it does not allow us to put the wall up because the tubing is in the way.
    A couple options are to build the wall out to make room for the water lines, or cut notches into the existing studs and use rigid pipe to route the lines flush with the studs.
    Is there another option we can do, or a is any one of the above better than the other?
    Thanks in advance,
  2. Terry
    Aug 17, 2004
    Pick up a 1-3/8" drill bit and put the pipes in the wall. You may need to rent a angle drill for that.
    Or.........you can notch the wall studs.
    With the old fiberglass enclosures, you can get away with a bit more as far as location of the piping.
Similar Threads: Help shower
Plumbing Forum, Professional & DIY Advice Chipped shower tile....what to do help!! Monday at 6:09 PM
Plumbing Forum, Professional & DIY Advice Shower cartridge HL40, Need Help to identify this part Jan 31, 2017
Plumbing Forum, Professional & DIY Advice Need help with shower/tub faucet Jan 21, 2017
Plumbing Forum, Professional & DIY Advice Help with shower valve Dec 11, 2016
Plumbing Forum, Professional & DIY Advice Please help I.D. this shower valve Dec 10, 2016
