Help with Tub/Shower Remodel Recommendation
Discussion in 'Shower & Bathtub Forum & Blog' started by JimT, Jun 27, 2005.
  1. JimT
    JimT New Member
    Jun 27, 2005
    See the first response for the actual question.
    Thanks.
    JimT
  2. JimT
    JimT New Member
    Jun 27, 2005
  4. MG
    MG New Member
    Jun 29, 2005
    Illinois - Near St. Louis
    Caulk is cheap - replacing stuff because you didn't caulk isn't.
  5. bbellabird
    bbellabird New Member
    Jul 1, 2005
    As a former Home Depot employee, I can tell you to stay away from the Sterling kits. The walls are very thin and break easily. Mustee(?) something that the name ended in an "ee" was what the remodeling contractors recommeded alot. Its not packaged pretty and doesn't have alot of selection of styles but the walls are much thicker. We very rarely got it back as a return. It's also priced cheaper.
  6. jdkimes
    jdkimes Engineer
    Engineer
    Littleton, CO
    I bought a Lasco brand, special order from Home Depot. It seems ok, but not what I'd call cheap $-wise. It was a 2-piece shower. I definitely caulked in between the two pieces. Make sure that support media like sand/cement mix is piled underneath the unit.
    After all was said and done, I wish I'd installed a tile shower. If you're a DIY'er and since you're retired you have lots of time ;) , consider it. Tiling is pretty inexpensive and if you take your time and spend some time at Johnbridge.com you can have a fantastic shower that is significantly better than fiberglass.
Similar Threads: Help Tub/Shower
Shower & Bathtub Forum & Blog Help identify tub/shower trim Feb 3, 2017
Shower & Bathtub Forum & Blog help identifying this tub/shower rough in to replace the trim Sep 4, 2014
Shower & Bathtub Forum & Blog Help Identifying a older Valley tub/shower faucet Jul 1, 2014
Shower & Bathtub Forum & Blog Need help finding replacement tub/shower handle with pushbutton diverter Jun 3, 2014
Shower & Bathtub Forum & Blog Cold Water in Tub/Shower Diminishing. Please Help Jul 31, 2013
