Help with trap configuration
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by thebordella, Nov 19, 2009.
  1. thebordella
    thebordella New Member
    Nov 9, 2009
    Ithaca, NY
    Hi,
    I have nearly completed my (first) half-bathroom renovation: new floor, new paint, new toilet, and...new vanity? Almost.
    When I removed the old vanity/sink, I cut out the old trap. As advised by members on this forum, I then cut back to the drain pipe coming out of the wall and attached a standard P-trap.
    However, when I tried to rough in my vanity cabinet, I discovered that the P-trap hangs too low to clear the lower shelf of the vanity. The wall pipe itself clears the shelf but the downward hang of the P-trap is about 3 inches too low.
    Whoever installed the (very old) vanity/sink that I tore out seemed to have encountered the same issue. You can see their solution in the first attached picture -- notice that there is an elbow on the straight wall pipe which turns up, then straight, then right, and then into what looks like a typical P-trap.
    If I recreated this configuration it would clear my vanity. But it looks non-standard. Then again, I am very new at all this. Can anyone describe what they did here and whether I could re-create this configuration?
    Note that most of what you see in that picture is long gone, having been torn out.
    The second photo shows the P-trap I added (before redoing the room -- it looks much nicer now!). But it hangs too low for the vanity.
    Appreciate your thoughts!
    thanks,
    Aaron
  2. hj
    drain
    Is that a backwater/check valve? If so what is it doing there? IF you do not raise the drain in the wall, and that can be difficult depending on how the pipe is arranged in the wall, ALL you can do is cut a slot for the trap to hang into.
  4. thebordella
    Nov 9, 2009
    Ithaca, NY
    Apologies for my ignorance -- I don't know what a backwater/check valve is.
    The only two valves I am familiar with in that first picture are the hot and cold cutoff valves.
    I could cut a slot in the new vanity for the low-hanging trap, but before I do, I thought I'd ask about the old configuration. More specifically, what's wrong with it? Why can't I do that? (Again, asking this totally naively).
    -Aaron
  5. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    In the second photo we can see some kind of an extra fitting/device in the drain line. It appears to have a cap on top which leads us to think it is some kind of a check valve. It should not be there.
  6. dlarrivee
    dlarrivee New Member
    Jun 28, 2009
    Foam/Fireproofing/Acoustical
    Canada
    It's an s-trap, and could possibly siphon the trap dry.
  7. Inspektor Ludwig
    Inspektor Ludwig Journeyman/Inspector
    May 11, 2006
    In the good ol' UPC
    That little white thingy on the trap arm is an "anti-siphon" port of somekind. I think it's just a built in Studor vent. But beware.....there's some new products that are trying to get approval in my jurisdiciton. I don't know the names but it's a swing check trap arm that "eliminates the sewer gas smell caused by faulty trap primers and dry traps". It eliminates the trap. I've seen two versions, one goes on the tailpiece of a floor drain and acts like a spring check, the other is designed to go on the trap arm of a sink or lav. Any other plumbers seen these?
    We said "NO WAY" thank goodness but every few months they try again. For the trap issue, as the guys said earlier, you'll either have to open the wall and raise or lower the waste inlet or you'll have to cut into the shelves to make room.
  8. hj
    "thing"
    IT is NOT an "S" trap, and from its appearance it is NOT a Studor or similar vent. It LOOKS like a backwater/check valve, but if so, it is NOT a replacement, or substitution for a trap. It is an ADDITION to the trap, and a poor idea at best. It also has NO function, unless there is also one on the toilet to prevent backflow flooding.
  9. geniescience
    geniescience Homeowner
    Nov 27, 2005
    ditto
    Wrong. Image #1 shows an S trap that was removed. The other thing that they are calling "it" is in Image #2.
  10. geniescience
    Nov 27, 2005
    ditto
    Please define "hangs too low". Your image #2 shows a P trap at the right place.
    From there you can Route Your Pipe any way you want, to reach the sink. So you could send a pipe straight up, to a tight elbow, and then over horizontally to another tight elbow under the sink drain tailpiece.
    Also, do you know that a P trap can double back on itself? It doesn't have to look like the letter P on its side. It can be a squiggle. You can turn the J part of it back towards the back wall. Try this, if you want to get the riser pipe to be located closer to the wall.
    Hope this helps.
  11. Inspektor Ludwig
    May 11, 2006
    In the good ol' UPC
    AHA! I knew I had seen that trap thingy before,
    it's a Genova "NovaVent" Anti-Siphon Trap. Google it and you'll see what "innovative" ideas plumbers are up against.
  12. Doherty Plumbing
    Doherty Plumbing Journeyman & Gas Fitter
    Jun 22, 2009
    Red Seal Journeyman Plumber & Licensed Gas Fitter
    Penticton, BC
    I have seen the spring type checks you speak of for floor drains. They actually work quite well. Are they ideal for areas where a trap primer would work great? No. But they're good for situations that warrant their use.
    The other type I have no seen.
  13. Inspektor Ludwig
    May 11, 2006
    In the good ol' UPC
    Terry,
    thanks for adding the pic. I'm a certified computer dummy. I really thought all the clicking and copying garbage I was trying to do actually worked! LMAO:D
  14. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    The ACE hardware store sells them, HD and Lowes probably do also. Are they code compliant? Unfortunately......................................................................................... yes
  15. Inspektor Ludwig
    May 11, 2006
    In the good ol' UPC
    Not where I'm at. We'd consider that to be an aav and therefore it would need to be installed per code requirements for drainage fittings.
  16. Doherty Plumbing
    Jun 22, 2009
    Penticton, BC
    You consider them an AAV? How? They're upstream of a trap so they're not vents.......
  17. Inspektor Ludwig
    May 11, 2006
    In the good ol' UPC
    D,
    I just read your last post on here, I think we were talking about 2 different things. The anti siphon on the trap arm is the one I'm talking about. The ones that go on the tailpiece I think provide a good answer to floor drains that have a dry trap problem.:D
  18. Doherty Plumbing
    Jun 22, 2009
    Penticton, BC
    oh ok. I can't remember even seeing an anti-siphon device in use on a floor drain before. We use the spring and bladder type.
  19. hj
    novavent
    They do not show pictures of their products, but state that the "NovaVent" comes in sizes from 3" to 24" which would not be appropriate for a lavatory drain.
  20. ChuckS
    ChuckS New Member
    Mar 17, 2009
    Aurora, CO
    I'm no plumber but I'd go with the previous guys solution. It appears to have worked and it's in the vanity so no one sees it.
Similar Threads: Help trap
Plumbing Forum, Professional & DIY Advice Shower p trap need help Mar 3, 2017
Plumbing Forum, Professional & DIY Advice P trap help Nov 21, 2016
Plumbing Forum, Professional & DIY Advice Help with new disposal trap configuration Oct 2, 2016
Plumbing Forum, Professional & DIY Advice P Trap to wall stub help Sep 15, 2016
Plumbing Forum, Professional & DIY Advice Little help w/ this p-trap Aug 26, 2016
