help with slow toilet problem
Discussion in 'Toilet Forum discussions' started by Ara, Feb 5, 2010.
  1. Ara
    Ara New Member
    Feb 5, 2010
    Salem, NH
    I have three toilets on two floors.
    My wife's the one who uses the master bath toilet most. It's upstairs and farthest from the main sewer line.
    The main bathroom is also upstairs and it often smells, but I don't think its a sewage problem, but a problem with aim... we have two boys under 10 years old...
    The downstairs bathroom is above ground in a third bedroom.
    We have a septic system that was installed three years ago (August 2006) and last pumped August 2009.
    When the upstairs toilets are flushed, the downstairs one gurgles. The upstairs toilets usually flush ok, but occasionally go slow. The downstairs toilet often flushes slowly - 5-10 minutes for water level to lower from rim to lowest (normal) level. It has backed up (filling with sewage) a few times and overflowed once (flapper got stuck open, clean water filled the bathroom and the attached bedroom-replaced the tank innards with $15 replacements from Home Depot).
    Here's the kicker... it does not back up, gurgle or misbehave in any way when the dishes are being washed manually or with a dishwasher (upstairs), folks are taking showers (upstairs) or the washing machine is used (lower level).
    Where's my clog? Is it something I might address? Do I likely need professional help? A plumber or a septic specialist?
  2. johnjh2o1
    johnjh2o1 Plumbing Contractor for 49 years
    Aug 9, 2009
    Retired
    Florida
    I would call a plumber to snake the main line first. If the line is clear then it is septic.
    John
  4. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    A clogged drain can seldom be cleared by a homeowner. The diameter and length of the auger is such that even if you can find the equipment to rent, it is too dangerous for a novice to use. This is one time you need to call on a professional. Don't even think about chemicals.
  5. Ara
    Ara New Member
    Feb 5, 2010
    Salem, NH
    OK folks, we all missed an easy one (and it cost me $120 for the Rooterman Service Call)...
    It was the filter on the Septic Tank ( I've got two tanks and there's a filter between the two.)
    Oh, and my wife has long hair!!
Similar Threads: help slow
Toilet Forum discussions Toto Carlyle II very slow to fill up-need help Oct 2, 2014
Toilet Forum discussions Can you help to identify this Toto Draket toilet part? Saturday at 9:06 PM
Toilet Forum discussions Install help for Toto Drake with closet flange below floor Jan 28, 2017
Toilet Forum discussions Need Help finding perfect toilet Jan 23, 2017
Toilet Forum discussions Help decided Drake ver1 Vs Ultramax 2 Jan 22, 2017
