Help with shower please!
Discussion in 'Shower & Bathtub Forum & Blog' started by patVan, Oct 23, 2005.
  1. patVan
    patVan New Member
    Oct 23, 2005
    Any help would be appreciated!!
    Husband recently installed a peerless shower faucet. We had warm and hot water but no cold and pressure not great. He has pulled control apart and is going nuts. He cannot see how to correct this. Cannot find any info on peerless web site. Any suggestions?
    Thanx in advance
    Pat
    New problem...now cold and warm only and no hot but still no great pressure. About to have very large hole in wall unlees someone can help!
  2. plumber1
    plumber1 Plumber
    Aug 7, 2005
    Florida
    shower
    It sounds like it may be a single handle faucet. Is it ?
  4. patVan
    patVan New Member
    Oct 23, 2005
    Yes...when we remodelled the new bathroom we switched to the single handle, not sure it was such a great idea though.
  5. Terry
    Aug 17, 2004
    adjujstin the hot side on a Peerless shower valve
    Most codes require pressure balancing in the shower.
    They only make single handle pressure balanced valves.
    You can get a pressure balancer for the two handle valves, but it adds a lot to the cost.
    Most single handles will have a high limit setting, that can be rotated higher.
    Pull the handle off and see if there is a way to swing the handle farther to the left at the end of the swing.
    If there is less pressure at the head, it would be just that.
    Shower heads are limited to 2.5 gallons a minute.
    The valve may be good for 5 to 8 gallons a minute. The valve is not the problem.
    Peerless® offers value-driven, proven designs that do not sacrifice style. Each faucet is designed to give consumers confidence in their purchase. Every faucet is backed by a Lifetime Faucet and Finish Limited Warranty.
    For more information on Peerless:
    800-438-6673
Similar Threads: Help shower
Shower & Bathtub Forum & Blog Help identify tub/shower trim Feb 3, 2017
Shower & Bathtub Forum & Blog help finding shower head diverter Jan 28, 2017
Shower & Bathtub Forum & Blog Help removing a brass shower drain Jan 4, 2017
Shower & Bathtub Forum & Blog Remodeling Shower - Need help with shower drain Dec 2, 2016
Shower & Bathtub Forum & Blog Help with removing Moen shower handle hub Nov 27, 2016
