Help with replacing shut-off valve
Lvrpl
Dallas, Texas
I'm replacing the sink and faucet fixture in a bathroom and have run into a bit of a problem I'm hoping to get some advice on. I understand that it's strongly recommended to replace the shut-off valve when doing something like this (and mine looks to be a 20-year-old original with the corrugated supply lines that I understand are prone to leaking).
However, one of my valve supply pipes leading into the old valve looks like it's already got a coupling on it, leaving very little regular-diameter straight pipe to put a new valve on. I was hoping to just use a new compression fit valve, but if I cut behind the couple, I won't have enough length of pipe, will I?
Any suggestions on what I should do here? I'm fairly handy but still a new DIYer when it comes to plumbing. Below is a picture. Thanks for any advice.
Dj2
California
You can try to heat up the coupling and remove it, heat it a bit more and clean the old solder away. Apply new flux and attach a new coupling, then a new short nipple for the new compression angle stop.
If it doesn't work, you can cut off the coupling, between the wall and the coupling, as close as you can get to the coupling. You will have about 3/4" of pipe out the wall to work with, then clean the pipe well and install a new coupling with a new nipple.
To hide the hole, use an adjustable flange.
Lvrpl
Dallas, Texas
Thanks for the advice so far. Would it work to just heat up and unsweat the valve on the end of the pipe as it is? I think if I could do that without cutting any of the existing pipe, I'd have enough pipe beyond the coupling to put a compression valve on...what do you think?
Sylvan
Still learning
New York
Easiest fix is to get the name of the existing angle valve brass craft, Watts etc and buy a new valve and remove the stem and packing gland (nut) and use the existing valve body.
I'm not a big fan of the corrugated shutoffs. They are single use, and if you move them even a little bit, they can crack. Anytime I'm replacing a toilet or faucet and I find them, they get replaced.
Your best shot would be to remove the coupling and install closer to the wall.
Cacher_Chick
Test, Don't Guess!
If you heat up and pull off the coupler and get all the solder off, it looks to me that there is enough pipe there for a new stop. There probably is not enough for anything but a flat/narrow escutcheon.
