Help with pressure
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by Phillip Gill, Jul 14, 2013.
  1. Phillip Gill
    Phillip Gill New Member
    Jul 14, 2013
    Texas
    I have just replaced every part on my well and it will not pressure up past 40 psi and when I opened the water faucets it drops to 10 and it won't keep up. I seriously have replaced every part. The tank. The jet pump the pipe the foot valve. The jet assembly at the bottom. The well head. S well headAbsolutely everything except the casing. Im Stumped as what it can be. What am I overlooking
  2. Smooky
    Smooky Well-Known Member
    Apr 4, 2011
    North Carolina
  4. Phillip Gill
    Jul 14, 2013
    Texas
    Yes I replaced that as well. Is there a particular way to run the lines. The way it is now I have the output line coming out of the pump to a T with a faucet I cat prime the pump with and it goes from there to another T that goes to the supply lines and into the tank on the other side or the supply line.
  5. Phillip Gill
    Jul 14, 2013
    Texas
    The tank is past the supply line T about 12 inches
  6. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    It sounds like a plugged jet. Maybe you got crud in it when you disturbed the well. With a plugged jet, all you have left is an impeller pump.
  7. craigpump
    craigpump Well-Known Member
    Apr 12, 2012
    Self employed water system tech
    Yep, sounds like a plugged jet. They make a funnel shaped screen that goes in the jet assy to keep the crap out of the jet. I always put them in.
    Unfortunately you have to pull the lines out to clear the jet...
  8. Phillip Gill
    Jul 14, 2013
    Texas
    I'll give it a look. I'm about to pull my hair out on this one.
  9. Phillip Gill
    Jul 14, 2013
    Texas
    Thank you for the information I will post what I find.
  10. Phillip Gill
    Jul 14, 2013
    Texas
    Thanks I will give it a shot
  11. masterpumpman
    masterpumpman New Member
    Mar 26, 2007
    Consult and Teach Well Drilling Internationally
    Virginia Beach, VA
    Yep, the 1/4" nozzle in the jet assembly is plugged with trash. Pumps don't build pressure the jet does.
Similar Threads: Help pressure
Pumps and Tanks Well Forum & Blog. Water is life. Helplease....Sprinkler pump and pressure tank Feb 18, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Newbie help with water pressure issues, thinking of a CSV Jan 3, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Help With Pressure Tank Selection Needed....Please Dec 1, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Need help with well and pressure tank hook up Oct 2, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Pump And Pressure Tank Help Apr 26, 2016
