help with Norris toilet
Discussion in 'Toilet Forum discussions' started by Shadrach, Mar 20, 2008.
  1. Shadrach
    Shadrach New Member
    Mar 20, 2008
    Salt Lake City
    I'm trying to snake a 1970's Norris front trap toilet without any luck. The snake seems to go up over the trap and snags on the down side. It doesn't bring anything back but seems to hit a porcelain wall. I don't know the internal shape of the trap or what it could be hanging up on. I never had any problems with it until it was lifted and then put back down by a plumber while our house was replumbed and the bath was retiled. No children so no toys.
    [​IMG]
    A Norris toilet bowl.
  2. Shadrach
    Shadrach New Member
    Mar 20, 2008
    Salt Lake City
    Is it even possible to snake it?
    Are the bends too sharp? Is it possible to be mounted enough off center to clog but not off center enough to leak? The toilet appears to be in good shape; no cracks, chips etc. and I don't have the money for a new toilet at the moment, but I am tired of plunging once or twice a week to get it to marginally work.
  4. jadnashua
    SOmetimes, if the plumber used an extra thick or double wax ring, it can squeeze enough out to restrict the flow. Also, if one of the wax rings with a plastic horn is used, it can create more trouble than it's worth and restrict the flow so it can clog. So, yes, an improper installation or an accident during install could cause it to clog. If the toilet didn't clog before, it should not clog now.
  5. jimbo
    jimbo Plumber
    Is that toilet being held together with Mighty Putty?? Looks all cracked, and it looks like a piece near the top is glued on????
  6. hj
    toilet
    Pull the toilet and look inside to see if something is jammed in there. Your snake should go right through it because I doubt that you have a professional one with a large head.
  7. Shadrach
    Shadrach New Member
    Mar 20, 2008
    Salt Lake City
    Thank you for your help. I guess there's no way to avoid biting the bullet and pulling the toilet. At least I now have some things to look for. By the way, the toilet in the picture isn't mine; it's the same model. The pic was added by another moderator.
  8. achutch
    achutch Member
    Oct 20, 2005
    Vermont
    That's a good thing that photo isn't yours. It's downright scary! Imagine being "taken short", running to that cracked old thing only to have it crumble to bits with you on it!! Wouldn't be pretty!
    Never heard of the Norris brand. Builder brands in Vermont in the 1970's were Mansfield, Borg-Warner, and some no name brands I that I couldn't tell you if my life depended on it. Sometimes you might find Kohler or American-Standard in the newer homes and to lesser extent Eljer. In the older homes, there were lots of "Standard"s, Eljer, and a few Kohler "TRENT" models.
    achutch
  9. Terry
    Aug 17, 2004
    I installed a lot of the Norris toilets like the one in the picture in the 70's
    Many of them in the Seattle area are starting to crack like that.
    I had some in my last home, they do need plunging more than the new ones.
    Norris was bought by Mansfield.
Similar Threads: help Norris
Toilet Forum discussions Can you help to identify this Toto Draket toilet part? Saturday at 9:06 PM
Toilet Forum discussions Install help for Toto Drake with closet flange below floor Jan 28, 2017
Toilet Forum discussions Need Help finding perfect toilet Jan 23, 2017
Toilet Forum discussions Help decided Drake ver1 Vs Ultramax 2 Jan 22, 2017
Toilet Forum discussions Help: Trickle sound and smell from Cimarron Jan 21, 2017
